Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 10-08-2021, 08:21 AM   #1
shelby5041
My Country: united states of america usa
Default Samsung LCD TV no picture backlight on no 12v at tcon
hi
i have a samsung lcd tv
it powers on with sound and backlight but no picture
all voltages from PS are good 12v 3.3v and 5v
whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
no 12v at the tcon fuse
i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
the odds of having 2 main boards with exact same problem is rare but could happen
could this actually be a bad tcon board? ..maybe is shorted out and not allowing main board to send the 12v?..or is this not a possibility.
thank you
shelby5041 is offline   Reply With Quote
Old 10-08-2021, 09:18 AM   #2
shelby5041
Default Re: Samsung LCD TV no picture backlight on no 12v at tcon
i think issue may actually be tcon...if i remove the tcon cable from the main board i now have the 12v at main board check point....so maybe tcon is shorted out which causes to lose 12v at main board to tcon?
Old 10-13-2021, 05:56 PM   #3
shelby5041
It was faulty tcon causing main board to shut 12v off
Replaced tcon ..$8...now works great
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
