Old 01-27-2022, 02:01 PM   #1
pingaroon
City & State: London
My Country: uk
Default Panasonic TX-37LXD85 blinking LED no picture
Hi everyone,
Just so you know, I have zero knowledge or experience of fixing TVs - I'm a laptop repair guy, who can do board repair, so hopefully you guys can guide me how to determine where the fault may lie.
So, TV has worked perfectly for years. Watching it tonight, the screen suddenly switches itself off and there is a red LED which blinks every few seconds forever. It doesn't blink a certain number of times, it just blinks on and on until the TV is manually powered off
Powering off the TV, and back on, the LED goes green and the sound from a roof aerial TV channel is heard for about 3 seconds, but with no picture, and it then switches itself off and the LED goes into its perpetual red blink cycle.
Can anyone help a total novice at least determine where the fault may lie (I'm handy with a multimeter). I've seen spare T-CON boards and inverter boards on ebay for this model and I'm hoping swapping one of those will do the trick.
Thanks in advance,
pingaroon is offline   Reply With Quote
Old 01-27-2022, 02:40 PM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Panasonic TX-37LXD85 blinking LED no picture
Shine a torch on it maybe from an angle if needed, hit menu see if you see an image at all or text.
nomoresonys is offline   Reply With Quote
Old 01-27-2022, 02:49 PM   #3
nomoresonys
My Country: U.S.
Try a couple simple resets, unplug tv for 5 minutes, plug back in try it, another, unplug tv press and hold power button on tv for 30 seconds, plug in and try it.
Old 01-27-2022, 02:51 PM   #4
nomoresonys
My Country: U.S.
Probably tho it's time to take the back off and investigate, can you post some good focused straight on pictures of the whole back and each board?
Old 01-27-2022, 03:10 PM   #5
pingaroon
My Country: uk
Hi, shining a torch reveals there *is* in fact a picture, so it looks like this is a backlight issue. I get no more than 3 seconds and it switches to blinking red LED mode.
Old 01-27-2022, 03:11 PM   #6
pingaroon
My Country: uk
Hi, none of the resets have brought it back, but I now know it's a backlight problem as the picture is in fact there.
Old 01-27-2022, 03:12 PM   #7
pingaroon
My Country: uk
Hi, yes I can do this tomorrow, thanks.
Old 01-27-2022, 03:20 PM   #8
nomoresonys
My Country: U.S.
Another easy step is in signature below.
(Signature) One of the first and least expensive things you can do when you have an issue is take the powerboard out of the tv, flip it over and look the solder joints over with a magnifying glass if needed, add a little flux to make the solder flow well and add solder to any joints that look even a little suspect. You can practice on a scrap pcb board if needed, careful not to bridge any joints, and always let the board sit for quite a while or discharge the big caps with an appropriate resister before working on it (safety first) to try to keep from getting shocked, it doesn't take 1000 volts to KILL, a lot less can kill, so be careful, it's only a tv.
Old 02-01-2022, 02:43 PM   #9
pingaroon
My Country: uk
Hi, I found someone who knows a lot more than me who's willing to repair it. I'll update what the fault was once done for the record. Thanks for your assistance (and the warning)
Old 02-01-2022, 04:57 PM   #10
nomoresonys
My Country: U.S.
Ok, thanks for the future update.
Old 02-05-2022, 10:01 AM   #11
pingaroon
My Country: uk
Hi, it was the inverter board - a few bad caps had blown and taken out some transistors along the way. All up and running again. Thanks
Old 02-05-2022, 10:33 AM   #12
nomoresonys
My Country: U.S.
Glad to hear it, thanks for the update.
