Hello All-
This is my first post. I have seen similar posts but none for the mode I'm having issues with.
Here are the details. When I initially plug in the TV, the white lower corner light will come on for about 10-15 seconds but then fades out. Also, I cannot turn the TV on; either with the manual button on the back of the housing nor with the remote.
I've tried all the online options I could find but nothing works. Based on a little research i believe its the Power Supply board (or maybe the main processing board). My board doesn't have the easily labeled stby 5 volts marking that I've seen on other vizio power supply boards....so I need some clarification as to which pin on my model is the equivalent to the standby power pin and i also don't know what the correct voltage reading i should be seeing with my multimeter.
Here are the power supply board markings and the multimeter voltage readings with the unit plugged in:
(ALSO, see the attached pictures)
1. VSNS - 2.4
2. LED-OUT - 64.2
3. LED-OUT - 64.2
4. LED-OUT - 64.2
5. LED-OUT - 64.2
6. GND - 0.0
7. GND - 0.0
8. GND - 0.0
9. GND - 0.0
10. GND - 0.0
11. +16 -16.2
12. AC-DET - 16.2
13. PS-ON - 3.2
14. +16VS - 16.2
15. +16VS - 16.2
I'm guessing the stby power pin is #13 "PS-ON," but I suppose it could be 1, 12, or 13. I don't know for sure what the abbreviations for 1, 12, and 13 stand for/mean.
I also can't find (on this model) what voltages I SHOULD be reading. A lot of similar threads say 5 volts is correct but i saw another that said as title as 3 volts could be correct.
Confusing!
Lastly I also read a post/thread that a lower than normal voltage, even though its reading something at the power supply board, might be enough to produce a reading on the multimeter that appress stable and adequate, but in reality the voltage is too low to actually power on the TV
Pictures attached.
Thanks again for everyones help!!
1. VSNS - 2.4
2. LED-OUT - 64.2
3. LED-OUT - 64.2
4. LED-OUT - 64.2
5. LED-OUT - 64.2
6. GND - 0.0
7. GND - 0.0
8. GND - 0.0
9. GND - 0.0
10. GND - 0.0
11. +16 -16.2
12. AC-DET - 16.2
13. PS-ON - 3.2
14. +16VS - 16.2
15. +16VS - 16.2
Confusing!
Pictures attached.
