Set comes on and works normally for about 30 seconds..Screen flickers slightly, then loss of video/backlight, audio keeps going. I can turn off and then back on and video/backlight returns for another 20-30 seconds, then goes off again. Power supply had areas that had obviously been hot. Replaced SMPS, really had no effect on symptoms.
Sharp LC42D43U Loss of video
Re: Sharp LC42D43U Loss of video
Resolder all the blue bypass caps and transformers. Measure with your DMM the resistance of the output winding and compare it to the others (take a paper and make a list). When you compare the transformers, they can't be more than 3% difference in the resistance readings. You have to do that on the Master and on the Slave boards.
