Hello
I picked up one of these tv's in uknown condition and have found that everything seems to be working except the 24v supply which powers backlights and audio. The 3.3 and 5 and 12v rails and stdby, ps and backlight ON signals are present when cycling the TV/supply. The 24v section can be heard trying to start, but just wont power on and gives no output (.07v). I have no experience troubleshooting SMPS and have learned a fair bit already but am now stumped on what to try or do next.
So far:
I have found that the electrolytic caps (sus'con HG, MG, SG non bloated and esr within spec) have no extreme faults.
I have found no shorts or faults in any of the through hole components, SMDs or final outputs. (Tests done with multimeter, ESR meter)
I've narrowed it down to after the PFC section I get ~400v to switching mosfets but then quickly the controller IC aborts start up and latches itself off. I probed the optocoupler feedback from the Rfmin pin which is supposed to output 2v reference. This 2v is not present when attempting to power the TV/SMPS on. If I disconnect the 400v supply from the mosfets and power it on normally the 2v reference will be present. Externally powering the Vcc and line inputs of the IC will also get the 2v reference to show up.
I'm stumped on what to try next. Seems like it is shutting down from overcurrent and never getting a chance to even read the feedback from the optocoupler.
Really would appreciate the advise of some experienced techs here
This thread contains schematics of the supply https://www.badcaps.net/forum/showth...ight=lc-42d69u
This is the mosfet/switcher controller https://cdn.badcaps-static.com/pdfs/...8e938828b4.pdf
I can also post pictures of MY board if needed.
Andrew
So far:
Andrew
