Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 06-09-2018, 08:40 PM   #1
goontron
5000!
goontron's Avatar
City & State: Wyoming
My Country: US
Line Voltage: 13kv
I'm a: Professional Tech
Default Need capacitor meter
I've seen all these chinese LCR jobs, but they don't go <6pF. I need less than 6pF. Preferably cheaper as im out a job (again....).
__________________
Things I've fixed: anything from semis to crappy Chinese $2 radios.
Marriage is the very definition of insanity.
Audiofools
Those who believe that $3,500 cables let them hear the audio more clearly, when the music was originally created with $25 cables.
Nothing says "women are equally capable" than infantilizing and damseling them to the point they need handicap bonuses to be "equal".
A small problem gets bigger if you ignore it. A big problem gets smaller when you attack it. When you attack a small problem, you get a solution.
My "Extremest" views: I will spread my knowledge to whoever will receive it. It is their prerogative if they do bad with it.
Sad..
If you can't convince them, confuse them.
goontron is offline   Reply With Quote
Old 06-10-2018, 11:42 AM   #2
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: Need capacitor meter
What exactly are you measuring?
picofarads add up very fast from moving wires around so there's a lot of error there to begin with...
eccerr0r is online now   Reply With Quote
Old 06-10-2018, 12:05 PM   #3
goontron
5000!
goontron's Avatar
My Country: US
Line Voltage: 13kv
^ RF caps.
Old 06-10-2018, 05:21 PM   #4
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Well, yeah, RF, but are you actually measuring capacitors or are you measuring cable capacitance or something to that extent? -- because around the 3pf range, the capacitance is so low that people tend to take two pieces of wire and twist them together. This means inaccuracy is rampant and you'll need to somehow design without exact capacitances unless you're building the caps on silicon, and you're not using a capacitor meter on silicon...
Old 06-10-2018, 06:19 PM   #5
goontron
5000!
goontron's Avatar
My Country: US
Line Voltage: 13kv
^ I've got a whole mess of ATC RF microwave capacitors that are unlabeled and i need to identify the ratings so i can finish building my 100W 70cm amp...
Old 06-10-2018, 09:16 PM   #6
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Wasn't it, if none fit the bill, make your own?
Old 06-18-2018, 07:48 AM   #7
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
BTW if you just need a quick check of a small pile of caps you can use my Sencore LC53 since we're (relatively) close by. However my "probe" is pretty shitty as proven when I tried to measure the cap of my varactor diodes, reading goes everywhere when I touch it.
You could also look for a LC53 as well, they may be available cheap since it's so old. It's designed to measure down to 1pF and has a resolution of 0.1pF, though once again, the numbers are crappy especially when trying to hook up pF capacitors especially SMT - I suppose I really should have some sort of jig to test them as touching them will throw it off.
Old 06-18-2018, 08:04 AM   #8
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
i think the atmel based component testers go down to a fraction of a picofarad.
never tried it though.
stj is offline   Reply With Quote
Old 06-18-2018, 10:59 AM   #9
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
The ridiculous thing about my LC53 is that if I zero the leads, it will happily report negative capacitance... easily giving -0.2pF or even -10pF hahahaha...
Anyway it was more for measuring leakage (capacitors) and Q (inductors). Not just value. Too bad it doesn't test "Q" for capacitors (i.e. ESR or tan δ)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
