CH341a SPI / I²C programmer
    Re: CH341a SPI / I²C programmer
    Originally posted by dskall View Post
    Have you used this? Says it has a virus
    Yes my virus scan said it was clean
      Mine gave me: Suspect!3f217d4dbfec quarantined
        Originally posted by caphair View Post
        What happened?
        Also I'm new to this eeprom thing, for future reference how would you know what size memory and whether it uses SPI or I2C when shopping for blank ones? Or is there one common type used in TVs that differs from a PC?
        25 series is SPI, 24 series is i²c
        the letter(s) after the number can be ignored for now,
        the next set of numbers relates to the size.
          if it's originally from me, then it's direct from the site of the author.
          anything over v18 is risky because they are in virtual containers that emulate a registered machine.
            yes im sure it was the one stj uploaded i just never installed it but i have just installed it now on my laptop as my old version was v1.13 so using v1.18 now, i have also just run a full malware bytes scan and nothing found so should be ok to use.
              Ok will try. What's the worst that can happen. It was quarantined
                stj has his version in post 2 in a zip file so maybe download that and use his version, as i have that many versions on a usb drive it could of come from another source.
                  It's from China and a lot of AV programs detect it as virus, but it really isn't. I'm running version 1.34 I believe. It's something like 5$ or 10$ USD's and you get free upgrades for life.
                  One thing to remember, run the program as administrator. Another thing, with my actual programmer, I have the option for 3.3V TTL logic or 5V CMOS logic. My programmer has to be set to pins 1-2 (CMOS 5V logic), even for TTL devices. It doesn't make a difference and hasn't damaged any chip, but 2-3 makes the programmer not work. I use an 8-pin SOIC clip that helps a lot.
                  Some people have had success reading and writing chips in circuit, but I haven't. I've always had to remove the chips. How are you hooking the chip up to the reader / writer?
                  When my chips aren't detected, it's almost always because I have a bad connection between the chip and the programmer. If the buffer and the contents are in disagreement, generally that means you have a bad connection somewhere.
                  If you need help and can't get it working, I can try helping some more. I believe there's a 1.34 or 1.35 version I can upload. Sometimes, the chips aren't directly supported. For example, it might detect it as a similar chip, but I read the datasheet, and if everything that matter matches, it's okay (like file size, manufacturer, etc). They're kinda neat.
                    hav try 4 chips with this programmer[CH341a] i always get chip disagreemet even when i whrite back up . pls help dont what d problem
                      presently i have 1 hasee f240 with bios pasword but scared to use d progammer not to kill d bios as experienced in d past
                        Does the latest version provide any noticeable benefit than 1.18?
                          the guy just adds more devices each version.
                          given the chips use a standardised commandset, you can probably use unlisted chips anyway.
                          so long as you match the overall, and sector sizes.
                            Can you send pictures of how you physically have the chip hooked to the programmer?
                              Yes, you can use unlisted chips if you match them. But there are more things added.
                              Here's a link to the changelog which shows what was fixed in the various versions:
                              https://skygz.taobao.com/p/rd917882....472fdc0eiPk6rf
                              Google translated since 1.18:
                              Code:
                              Version 1.34 2017-7-8
                              Repair S25FL256 read and write BUG
                              Fix ignore ID detection option BUG
                              Added FM25F005, FM25F01, FM25F02, FM25F04, FM25Q08, FM25Q16, FM25Q32
                              Version 1.33 2017-6-15
                              Remove heading display file path function, replaced by log records
                              Fix the BUG that the previous version was writing/erasing
                              Add LE25FU106, LE25FU206, LE25FU406, LE25FS406
                              Add GD25D05, GD25D10, GD25Q21, GD25Q41
                              Add GD25LQ40, GD25LQ80, GD25LQ16, GD25LQ32, GD25LQ64, GD25LQ128, GD25LQ256
                              Add MX25V1006, MX25V2006, MX25V1035, MX25V2035, MX66L51235F, MX66L1G45G, MX66L2G45G
                              Add MX25U25635F, MX25U25645G, MX66U51235F, MX25U51245G, MX66U1G45G, MX66U2G45G
                              Version 1.32 2017-6-1
                              Increase the automatic naming format of the file when the operation option is saved: yyyymmddhhnnss.bin
                              Added 25AA512, 25LC512
                              Add MX25L6435E, MX25L25645G
                              Add W25Q16CV, W25Q32CV, W25Q64CV, W25Q128CV
                              Version 1.31 2016-6-1
                              Increase OTP size in detection results (Chip with OTP area will be displayed)
                              Add ignore ID detection option switch, test failure can continue to operate
                              When adding data can be specified from a file location address, load to a buffer location address. (Not valid for HEX format files)
                              Increase the operating range; that is, read, write, and erase the data of the specified address range of the chip.
                                  Only valid for 25 SPI FLASH (block\sector erase mode), some models do not support.
                                  Other series chips (24 EEPROM, 25 SPI EEPROM) are not supported.
                              Add EN25QH80, EN25QH16, EN25QH32, EN25QH64
                              Increase N25Q64A
                              Added W25Q64DW, W25Q128DW, W25Q256BV
                              Add MX25L3233F, MX25L3235E, MX25L3236F, MX25L3239E, MX25L3273E, MX25L3273F
                              Add MX25L6473E, MX25L6473F, MX25L6475E, MX25L6433F, MX25L6436E, MX25L6436F, MX25L6439E
                              The above MX25L**73 models are only increased for testing, and normal reading and writing are not guaranteed.
                              Version 1.30 2015-11-17
                              Part of the code to optimize the function of the OTP area
                              Rebuilding the chip database structure
                              Increase log function
                              Before modifying any operation such as read\write\erase, it is necessary to automatically detect the chip and no termination of the chip is detected.
                              The check can be done after the read is completed. It can be turned on or off in the options. The default value is off.
                              When the repair software first runs, it appears stuck
                              Fix the bug that W25Q256FV can not be programmed
                              Added AT25DL081, MX25L25635F, MX25L12839F, MX25L12873F, MX25L25639F, MX25L25735E, MX25L51245G
                              Increase the INTEL 160S33B, 320S33B, 640S33B
                              Other minor changes are optimized
                              Version 1.29
                              Fix the bug of adaptive form size
                              Added read of Unique ID Number for WINBOND's Q series.
                              Added options to allow multiple instances
                              Optional option allows you to skip empty data
                              Fixed a BUG that did not reset read/write status after forcibly unplugging.
                              Added 25 SPI EEPROM series chip support. Includes 28 models
                              Increase (W25Q20BW, W25Q40BW, W25Q80BW,
                                  W25Q16DW,W25Q32DW,W25Q64DW,W25Q128FW)Support
                              Increase W25Q32FV, W25Q64FV (to be tested)
                              Added AT25DF081A support
                              Correct chip ID of MX25U1635E, MX25U3235E, MX25U6435E
                              Version 1.28
                              Added EON EN25QH128 support
                              Added SST25LF020A support
                              When adding an unrecognized chip, the red word prompt is displayed below the detection information.
                              Fix a shortcut error
                              Change the software registration algorithm, old users update to this version, you need to find yourself to register.
                              Version 1.27
                              Added WINBOND W25Q256FV, Test, Unsupported
                              Added MXIC MX25L2026, MX25L12835F support
                              Correct S25FL128 chip ID to avoid identifying BUG with S25FL129 error
                              Added support for WIN7 and above systems to display progress bar effects on the taskbar
                              Improved chip detection capabilities, such as the presence of multiple similar chip IDs, enumerated for selection
                              Improved auto button to add menu (ie default auto programming option)
                              Version 1.26
                              Fix the status bar in the English language or Chinese BUG
                              Fix the bug that the chip with OTP cannot erase the Main Memory area
                              1.25 beta
                              Adjust the display mode of each component in the operation option window
                              Added one-time read and write function of Secured OTP area (currently only supports OTP of MX series ICs)
                              Add several MXIC chip models
                              Add several KH chip models
                              Add an ESMT chip model
                              Improve driver not installed or incorrect dialog, optional ignore this prompt.
                              Version 1.24
                              Fix bug in multi-language in Open\Save dialog
                              Increase setting Optional use Windows system Open\Save dialog
                              Fixed MX25L25635E chip 32MByte/256MBit capacity read\write failure BUG
                              Correct device ID of several models of chips so that they can be identified effectively
                              Fixed bug where opening large files and then opening small files without clearing buffers
                              Version 1.23
                              Simultaneous release of CH341AFree.exe V1.0 free version, only basic functions, free registration, only supports universal 24\25 chips, does not support special chips such as SST
                              Optimized the write speed of SAT\ESMT's AAI programming mode, improved a lot, but still slow
                              When the byte programming mode of SST\ESMT is increased, the data that is encountered as FF is directly skipped and the write time can be reduced.
                              Increase the amount of data that encounters the entire page as FF when the conventional chip is written. Skip directly to reduce the write time.
                              Increase the display file path at the title
                              Increase to the corresponding error location after verification fails
                              Increase the menu buffer -> reset, used to reset the buffer reset to FF
                              Version 1.22
                              Add software to try out features before registering
                              Correcting the problem that the termination function cannot be terminated without identifying the chip
                              Add 3 chip models
                              Corrected the problem of invalidation of the original registration file after the operating system was reinstalled without replacing the hardware.
                              Increase driver not installed or incorrectly installed
                              Version 1.21
                              Uniform programming characters changed to write
                              Add N chip models
                              Fix the wrong name of a brand chip
                              Fixed bug of AT25F512A with 128 byte/page programming
                              Fixed BUG slow writing of AT26 series. Note: This series of IC is not good compatibility (new IC measurement, fast reading and writing)
                              Version 1.20
                              Change the authorization method to one machine
                              Fixed bug that individual chips cannot be erased
                              Fix bugs that are easy to "write operation timeout failure"
                              Correct the device number of the NN chip in the database so that the detection function can be detected
                              Optimize database chip names in order
                              Database removes 3 duplicate models of chips
                              The chip database adds 4 more chips
                              Fixed BUG that 26 series chips can not read and write, but the writing speed is very slow, similar to SST\ESMT
                              Added option to use block/sector erase mode, automatic selection of block or sector erase commands when enabled, and use of bulk erase commands when disabled
                              Fixed BUG error when registering the mouse at the chip select
                              Version 1.19
                              Fix special chip protection problem of KH25L8036D
                              Fixed delay in the correction option can not save the BUG
                              Version 1.18
                              When using the automatic operation, when the verification fails, two message dialog boxes pop up.
                              Adding automatic operation can be delayed for a certain period of time before programming, which can be set in the options. (This function is for unstable chips. This option only works when automatic operation.)
                                Also, are you running the program as administrator? I always do. I'm assuming it shows that your programmer is successfully detected in the lower right corner of the screen...
                                  Would be nice if they would add the option to add your own chips. I saw a programmer and it had that option. Don't remember which one it was
                                    For the Chinese CH341A Programmer software?
                                    I thought the same. I was thinking of building off some open-source programs that Stj linked to (I got some Linux drivers too for the CH341 chip, serial and parallel).
                                    Thought when I found some time, as a community, we could come together, setup a github page and just write a GUI for Windows / Linux where users could add their own chip parameters and maybe upload them to some database. We'd store the database on the github page and could have the program auto-update the database with the click of a button or have a preference they can click to always check for the latest database.
                                    I dunno if it'd catch on though and it's a bit of work, plus I got a few other projects going on now. It'd have to use something like the GTK Libraries for easier porting from Linux to Windows, and maybe some library that's available on both OSes for USB communication or something. It was just a thought.
                                      This is the program I found: https://cdn.badcaps-static.com/pdfs/...f45c4d5b71.pdf
                                        How's that working for you? I see it requires .NET Framework, meaning it's a Microsoft Windows program, no Linux version. Is it free and does it support a lot of readers / writers?
                                        I like how you can add your own devices. I thought you was using one of the softwares Stj talked about, the Chinese one or one of the open source ones.
                                          Linux can run .net junk using the MONO package.
