Off topic question perhaps
This mobo has possible start up problems
I am testing this with;
CPU - Intel PIV 3000MHz Prescott 650 2MB cache FSB 800MHz;
HSF - Intel stock Alu HSF rated to PIV 3000MHz, silver artic compound;
RAM - 1 x Elixir PC3200 200MHz 512MB DDR-I Unbuffered SDRAM;
On-board VGA - Integrated Graphics VGA Port
AGP Port - Asus V9520/TD/256M AGP 8X 256MB TV-Out DVI VGA
PSU - WinPower 700W Dual Fan
http://www.bossecomputers.com/Produc...N-700WDUAL.htm
As I am simply jumpering the front panel header, I have the following
issue(s);
1. Sometimes the PSU fails to start.
The PSU fan appears to start to spin up but when
my screwdriver is across the postive and gnd. pins of the
FP pwr. switch but when lifted from the jumper - the PSU stops
2. On other occasions, it will start but the BIOS will not load.
I removed the batt. (which is ok) and left the mobo overnight.
Started it again today and hey BIOS loads andt the
POST diag. card reports 24 1C!
From the AMIBIOS8™ (it's an AMI BIOS) Check Point
and Beep Code List, 24 details;
Uncompress and initialize any platform specific BIOS modules. GPNV is
initialized at this checkpoint. No problem there
Why am I having this problem, is it the PSU?
Does the FP pwr. switch need to latch the PSU within a specific
amount of time? Come to think of it, I have seen this problem
with another s775 mobo, an Intel 915PBL. However, with that mobo,
once installed in a case the issue disappeared
Any suggestions?
issue(s);
Any suggestions?
