Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old Yesterday, 01:43 PM   #21
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: What kind of diode is this?
you probably need to clean the old crap out and re-lube them.
stj is offline   Reply With Quote
Old Yesterday, 02:03 PM   #22
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
They are brushless DC motors and they use electronics to synthesize AC. The electronics will automatically generate the correct phasing so that there's no need for the capacitor to do so to generate the other phase (compare to 3-phase AC motors instead of 1-phase AC motors.)
eccerr0r is online now   Reply With Quote
Old Yesterday, 02:33 PM   #23
redwire
City & State: Alberta
My Country: Canada
Rule out mechanical problems before going into the electronics.
I would first clean out the old lube with q-tip and IPA. After 35 years, the original grease and oil is gummed up. The worm shaft for the head stepping motor needs grease, and guide shaft needs oil. The disk motor probably needs oil but should not be stiff as to not start spinning without help.
The disk motor circuit may be the same FC-9 as the later OA-32V pcb 1-609-924-11
I'm not sure what the "FG print coil, 60 pieces" is on CN1, as a tachometer circuit?
It's not like an AC motor with start cap. There's several 1uF,10uF ,100uF caps which could upset the tach. No datasheet on Sony CX-069A it might be a PLL for speed regulation.
For the diode D2 smoking, if the wiring is not shorting and the connector was not put on backwards, I would check the resistance of the stepper motor's four windings, and continuity to the motor case.
A fault to GND on CN5 pin 1 or 2 is what I would see overloads the diode.
redwire is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
