Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools
Old 09-14-2017, 07:56 AM   #541
case sensitive
City & State: Southampton
My Country: United Kingdom
I'm a: Knowledge Seeker
Default Re: Dell 3008wfp faulty power supply
Uploaded a video of what happens (epilepsy warning!!):
https://youtu.be/pyA_5wPEIKQ
case sensitive is offline   Reply With Quote
Old 10-01-2017, 03:03 AM   #542
Curamrda
City & State: Plzen
My Country: Czech republic
does anybody know where to get new tcon and tab ic? for this monitor??
Curamrda is offline   Reply With Quote
Old 10-22-2017, 05:33 PM   #543
maticma
City & State: ZG
My Country: CRO
I repaired PSU 2or3 years ago(no power at all), as I can remember I just replaced diode D22.
Monitor worked again perfectly until today.
Now problem is different, lower 1/4 of LCD does not work (black or low light stripe lines on that area, see pic).
Any idea what could be wrong?
Thanx.
maticma is offline   Reply With Quote
Old 10-23-2017, 12:15 AM   #544
dftntm
City & State: Rome
My Country: Italy
You can try to touch the connectors on the side of the LCD panel, to check if there is a bad contact.
You can also watch norcal715's videos on YouTube, like this one: https://www.youtube.com/watch?v=WuwG5wqxTpE
dftntm is offline   Reply With Quote
Old 10-23-2017, 05:31 PM   #545
maticma
City & State: ZG
My Country: CRO
Tried to press side connectors but no luck.
Will try to clean cable connectors.
Thanx
Old 12-18-2017, 10:26 AM   #546
Riffey
City & State: Northamptonshire
My Country: UK
Hello, I have a similar fault on a 3008wfp, where the power light goes on then off and just a blank screen, I have check D22 and it tests ok with meter, but change it anyway to no avail,somebody somewhere has got the circuit diagram of this monster.
Riffey is offline   Reply With Quote
Old 02-21-2018, 02:23 AM   #547
damoj11
City & State: Perth W.A
My Country: Australia
I have the same problem with my Dell 3008WFP monitor suspect the power supply is faulty but I am a novice at component level repair any help would be appreciated. I have attached some pictures of the board front and back. Grrr why does it only allow me to upload one file?????
damoj11 is offline   Reply With Quote
Old 02-26-2018, 09:40 PM   #548
deepaksesh
City & State: Bangalore
My Country: India
Recently repaired my 3008 by replacing Diode d22. Thanks to this wonderful forum, saved nearly 20k Indian Rupees.
If anyone else needs info, i will be glad to help.
deepaksesh is offline   Reply With Quote
Old 03-05-2018, 03:07 PM   #549
damoj11
Thanks for the advice I will start with this and see how I go.
Cheers
Old 04-21-2018, 03:42 PM   #550
jaaa1976
City & State: Thetford
Hello..I received faulty DELL 3008 WFP from ebay ..but psu is damaged too much ..somebody learn how to soldering...but me HP ZR30w 30" Widescreen IPS LCD Monitor have same lcd panel LM300WQ5..so i fix lcd panel from dell to hp but look on picture..is lcd display also faulty? i also swap lvds cable and 2 working boards from hp zr30w..but only vertical lines.
jaaa1976 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
