Lenovo 305-15IBD - completely dead - no signs of life
    I have a Lenovo 305-15IBD. It's dead.
    No power, No lights, no reaction to power button.
    I have taken a look inside and tested the DC jack. I have 20.76V on 2 pins on JDCIN1 socket on the motherboard.
    I also have exactly the same laptop but fully working. I did some measurements and the working motherboard have 3.3V and 5V on PU202 (when charger connected, before power button pressed). Dead motherboard doesn't have 3.3V and 5V on PU202.
    Could you please give me some advice on how to test/diagnose the motherboard further. I'm not sure what to do next as I'm a beginner. I would like to learn. Thank you
    Re: Lenovo 305-15IBD - completely dead - no signs of life
    Check the voltages on the mosfets near the DC jack.
      Try this Schematic
      Test Pl101 Pl102 for +20V
      ADP_ID 3.3V ,AC Adepeter 90W?
      RTC Battery 3.3V
      PQ301 fet pin 5.6.7.8 +20V pin4 8.8V pin 1.2.3 +20V
      Voltage on PQ302 must be the same measurements
        PL101 and PL102 - 20.75V
        RTC Battery - 3.32V
        PQ301 - pin 1.2.3.5.6.7.8 - 20.75V, pin 4 - 8.79V
        PQ302 - pin 1.2.3.5.6.7.8 - 20.75V, pin 4 - 8.79V
        PQ302 - pin 1.2.3 - 20.75V, pin 4 - 20.26V, pin 5.6.7.8 - 20.69V
        ADP_ID 3.3V ,AC Adepeter 90W? - I'm not sure how to check this. AC Adapter is 65W
          Now test 5/3ALWS Voltage page 46 Schematic PL402 PL404
          PU401 pin5 and PU402 pin7
            PL402 - 0V
            PL404 - 0V
            PU401 pin5 - 0V
            PU402 pin7 - 5.19V
              test Voltage on PU301 pin 1 2 5 6 16 20 ?
              desolder jumper PJ401 and test both sides of the JUMPER with the multimetre on Diode mode 1-2 jumper) ?
              PU401 pin 5 test with the multimetre on Diode ?
              PU401 Voltage on pin 7 8 2 ?
              PU402 Voltgae on 1 5 8 ?
              desolder jumper PJ402 and test both sides of the JUMPER with the multimetre on Diode mode 1-2 jumper) ?
