Can you post your bios backup .What problem are you having .
hi yes I have back up of BIOS, but I backup after I make changes in bios, I disabled usb xhci and now the keyboard and usb don't work, I try bios from chuwi lapbook and prestigio but with bios from prestigio I can only install w10x86, and with bios from chuwi I can install w10x64 but not work sound(driver is instaled but no sound) and not work wifi in device manager is not listed wifi, and lan not work correctly.
what I need is, if someone can to edit my bios to be enabled usb
SMDFlea, and rioreno, sorry that i misleading you, probably I soldered bad the chip, with bios from smdflea computer start but the setting in bios is not changed and usb and keyboard not working BUT with your BIOS rioreno the bios is reset, and all seems to work, right now I installing w10x64 and will announce you if all is working, very very big THANK YOU
Hello.
I need help with my BIOS from Haier HI133L - when I change "OS Image Select" from "Windows 8" to "Android" my laptop stop working and the power light is flashing and black screen. HI133L have same schematic (motherboard) like kiano slimnote15.6 but without HDD - it have 32Gb SSD + 2GB RAM. Somebady please help me. BIOS dump attached to this message.
Hello.
Greetings..
This, nvram reset to default setting...
goodluck and please confirm
Goodluck.
Remember friend, every bios has a different nvram structure.
So you should first look at a number of pure different bios brands obtained from the manufacturing site as a reference.
Goodluck.
Seem I need more lot talk to you to improve my skill of fix BIOSes.
Moga ente tetap sehat bro..alamat masih pajak atas?
Hi!
i'm new to the forum, i need help restoring bios dump on my sbartbook mediacom s14, after setting android to default s.o. to start the smartbook I have the blank screen and the power led blinking, I dumped the bios but I have no idea how to reset nvram
