This is a great website!
My computer quit working entirely and, with no bios beeps, members at two other websites were unable to help me. Having unplugged and removed whatever I could, I finally decided to go all the way, so I took off the fan and heat sink on my m/b.
Beneath, right next to the cpu, were four bulged out and dirty radial caps.
When I read over the list of bad caps printed here at badcaps, I was able to figure out the brand name of the caps, which I had thought was not printed on them. The "O" on the cap was drawn oddly, I thought it was some sort of symbol, like a sun or a planet. I had thought the "st" in lower case next to the planet stood for some sort of specification. It turns out that they are Ost capacitors, so now I have a company to be pissed off at! (Always satisfying, right??)
I want to replace the caps, but I'm confused about the voltage. Here's why. Printed on the caps is:
Ost
105 (degrees)
RLA
0417
4 v
680uf
However, when I went to the OST website and found the "RLA' product series, it says that the cap has a voltage of "16v." This seems to contradict the "4 v" which is written on the label.
Ost product listing
Another issue I'm having is in regard to the temperature. I did find 680uf 16v caps at parts express which are 8mm x 8mm. (They must be 8mm in ht. or less because they go under the heat sink, and 8mm or less in diameter because three of them sit shoulder to shoulder along side the cpu.) But the caps I found at Parts Express are only 85 degrees and not 105. Owing to their location, this has be a bit worried.
Parts Express
I have spent quite some time searching and not finding, and at this point hope to get some advice. Does anyone know where I might obtain some 8mm X 8mm 680uf caps good for 105 degrees?
And, should I obtain 16V?
Ost
105 (degrees)
RLA
0417
4 v
680uf
Ost product listing
Parts Express
