I am trying to identify and buy a voltage regulator.
The casing is somewhere between SOT563 and SOT963.
So it's 6-pin. Lenght of the capsule is about 1.2mm and the width 1mm.
Codes on the capsules are:
AUDJ833 or AUDM633 or AUDK897. All codes are used in the same model of device as a voltage regulator from +5v down to +3v3 so they should be interchangeable.
pin2 is ground
pin3 is Vin +5v
pin6 is Vout +3v3
pin4 is connected through an L to pin6
I spent quite a while looking for a replacement to buy.
Any help would be highly appreciated.
pin2 is ground
pin3 is Vin +5v
pin6 is Vout +3v3
