Old 10-28-2012, 04:42 PM   #21
fddizon
City & State: Forbidden
My Country: Philippines
Line Voltage: 220v 60Hz
Default Re: MSI CR400 no display
Originally Posted by dycc View Post
do you check the voltage without the cpu ???????
the isl6262 is the driver of these mosfets so their gates are connected to it .
as you said you had already change it with a good one ,check if isl6262 is supplied with the 19v ;5v; and 3.3v; that is necessary for his functioning
hi,
maybe i need to get another isl6262 for another test.
will try later and post the result.
fddizon is offline   Reply With Quote
Old 10-29-2012, 06:51 AM   #22
fddizon
Originally Posted by xaviero1412 View Post
yes , i have one....
give you clues,
your problem is not chipset failure.
your problem is not ISL6262 failure.
thats for sure....
can you give us the solution?
thanks
Old 10-30-2012, 02:27 PM   #23
tomodachi
tomodachi's Avatar
City & State: Istanbul
My Country: Turkey
Line Voltage: 220
Originally Posted by fddizon View Post
is it possible to flash msi bios without display?
acer can flash it without display.
regards
You need a flash programmer device to flash your BIOS my friend.
tomodachi is offline   Reply With Quote
Old 11-05-2012, 08:48 AM   #24
kenttech16
City & State: Souther Luzon
Line Voltage: 220VAC 60Hz
What voltage of tantalum did you use sir? 2.5v? Did you removed the NEC/Tokin type capacitor and then put the smd capacitors on the terminal both ways with proper orientation? If all are correct then it is possible that reflowing the gpu might caused the damaged? I just hope i'm wrong with this one.
For me, it works with all the MSI CR400 with Nvidia I had repaired before, and today another one of MSI EX460 with ATI with power led lit up, sleep led also lit up and hdd led is lit up and no display. But I did first the basic procedures, clean the memory module, replaced with good one to isolate. then, removed the cmos battery to reset the board settings, also removed keyboard,odd and hdd to be sure if something is wrong or triggering the no display problem and with only the board, processor and memory still to no avail. Also did replaced the processor and yet no luck.
That's the time i added two 330uf tantalum first besides the vacant capacitor terminal at the processor and voila it works for me again.
kenttech16 is offline   Reply With Quote
Old 11-05-2012, 01:27 PM   #25
tehzeeb786
City & State: Pistoia
My Country: italia
I'm a: Student Tech
same model cm here for repair is dead complete 2 cap is 1 near processor and 1 back side layer some one 9 how can i change cap o ?
tehzeeb786 is offline   Reply With Quote
Old 11-05-2012, 05:05 PM   #26
fddizon
kent,
thanks for the reply. i used 4 tantalum capacitors without removing the proadlizer capacitor. just tapped on the proadlizer pads.
i just did a mild reflow on the gpu which i think not destructive.
i used tantalum capacitors taken from defective motherboards.
will try again tonight.
thanks
Francis
Old 11-05-2012, 10:16 PM   #27
masud
City & State: Dhaka
My Country: Bangladesh
100% it's a nec token damage problem. try with capacitors 330mf x 4.
masud is offline   Reply With Quote
Old 11-05-2012, 10:21 PM   #28
fddizon
masud,
i did put 4 330uf capacitors but not removing the proadlizer. do i have to remove it?
regards
Old 11-06-2012, 07:41 AM   #29
trebo
City & State: Cardiff
My Country: Wales, UK
masud,
regards
Rainbow done something like it and it worked for him, see here at this link
http://www.badcaps.net/forum/showpos...92&postcount=8
trebo is offline   Reply With Quote
Old 11-07-2012, 12:06 AM   #30
fddizon
trebo,
if that is the case then, the proadlizer might be good and not defective.
maybe the gpu is really shorted.
tnx
Old 11-07-2012, 08:44 AM   #31
kenttech16
kent,
thanks
Francis
I just thought you removed the proadlizer cap and then replaced it with tantalum. Well, you can do it also without removing the proadlizer by putting smd caps 2-3 to vacant pads just besides the proadlizer area as shown on the attached picture for smd caps. It always works for me. Just let me know what happened.
Old 11-07-2012, 08:45 AM   #32
kenttech16
Agree 100%!!! Because it always works for me every time I had that kind of problem with that model and the likes.
Old 11-07-2012, 10:13 PM   #33
fddizon
what i did earlier is this to no avail.
i soldered 4 330uf caps to solid wires and tapped it to proadlizer pads, the same result.
will try to solder the caps on suggested pads.
tnx
Old 01-19-2013, 06:36 PM   #34
fddizon
I think your problem is the same with toshiba satellite L300 series,if you are familiar with this one and if not you can search it here. The NEC/TOKIN is the culprit, it is the same with the one on top of the cpu (encircle in red) see attachment. Try to replace it with smd capacitor 4 X 330 uf 2.5v.
I've already tried and repaired 5 more of this model and and voila it works for
me. Before I also thought it was the Nvidia gpu was the problem, tried reflow and yet no luck then i suddenly realize the capacitor is the same with NEC/TOKIN from Satellite L300.
Hope this works for you.Good luck and let me know what happened.
Ken,
your a pro bro. it worked when i put 3 caps with marking NEa JE8 capacitors. too bad that the processor overheats and turn off after a few minutes.(overheat protection) i guess the capacitors value does not fit with the solution.
i am ordering 4 330uf 2.5v tantalum capacitors later. will update you soon.
thanks and regards
Old 02-11-2013, 08:15 AM   #35
markuz1787
City & State: Makati
My Country: philippines
fddizon,
Hi any update regarding this kind of problem?.. I have the same problem on my cr400. did you tried 4 330UF 2.5V tantalum capacitor. Did it fixed the problem?? thanks!
markuz1787 is offline   Reply With Quote
Old 02-12-2013, 06:38 AM   #36
fddizon
Originally Posted by markuz1787 View Post
fddizon,
markuz,
not tried with 330uf yet.
but im sure it will go good with it.
i used lower capacitance and display showed, meaning it will work as ken assured. mine turns off after a while, because i used different capacitors unlike suggested.
regards.
give it a go bro...
Old 02-24-2013, 12:46 AM   #37
kenttech16
fddizon,
Mark,
Tried and tested and so far for me it works without any conflict with the performance of the laptop. It is just the same with Toshiba Satellite issues with Nec/Tokin cap.
Give it try first and hoping and looking for you to fix it as i did.
good luck then
Old 02-24-2013, 02:08 AM   #38
welhim
City & State: dumaguete city
Talking Re: MSI CR400 no display
when powered on, no display, fan spinning, power led is lit, sleep led is lit.
5v 3.3v alw are ok. coils near cpu has .01 and .02 volts.
what does this mean?
pre...anim na 330 capacitors mag work yan for xure!!
welhim is offline   Reply With Quote
Old 02-24-2013, 02:26 AM   #39
welhim
tomadachi,
i did your suggestions to no avail. still no display, fan spins no vccore voltage.
pre try moh 6 na 330 na capacitors...gagana yan for sure
Old 02-26-2013, 07:38 PM   #40
markuz1787
Mark,
good luck then
Hi ken,
Im having problem finding the 330uf 2.5v tantalum capacitor at manila Philippines. Do you know where i can find it here?
Mark
