DABLYDMB8E0 Rev E.
    DABLYDMB8E0 Rev E.
    DABLYDMB8E0 Rev E.
    totaly dead with no power, only i get 19v on the source of the first mosfet AON6414A on the drain i get 0.5v , changed it with same results
    i removed the second mosfet with the same result
    http://www.mediafire.com/folder/6xlay65uyyqez/del
    Re: DABLYDMB8E0 Rev E.
    Please attach schematics so we can help.
    Either the mosfets are bad or they aren't "switched on". Measure gate voltage.
      i cannot find the schemtic,
      the gate is 0v
        is that the right board number, DABLYD or DABLID
          dablyd, i forgot to mention that there is 0A when i test it, no current at all
            sory the folder above was empty:
            https://www.mediafire.com/folder/6xlay65uyyqez/
              Attach the files to your message directly.
              Check both MOSFET for short across drain/source/gate.
              Measure resistance to ground after 2nd MOSFET.
