Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 06-19-2017, 05:39 PM   #1
pogosa
City & State: SATX
My Country: USA
I'm a: Knowledge Seeker
Default Samsung UN55JU6700F No picture, no sound
I'm not super knowledgeable of tv's but I think I have enough knowledge to get me through this repair (if possible) - let's hope
I have a Samsung UN55JU6700F that has no picture or sound. When plugged in it is clear that power is supplied (screen glows, optical audio light on, and power light indicator responds to remote control). It appears that the backlight powers up as well (see second set of pics)
I tried to use a flashlight but could not see anything on screen. I am using the S4 for the remote since I do not have a remote so it may make things difficult.
When I turn it on, there is an intermittent, seemingly random clicking noise. Sorry for the reference, but it sounds like "kek."
I opened the back and didn't see any issues with capacitors. I did notice a little bit of dried liquid but it didn't seem to have made contact with anything but one connector (I'll attach a picture from my phone in just a few because I don't know what these are called). http://imgur.com/qFUNv3Y
Edit: I figured out that if I pressed the volume (up or down) the clicking (kek) noise occurs with each click and is coming from the area where the liquid spots were.
Here are pics of backlight with main board connected and disconnected
Power board connected http://imgur.com/0xn55ZV
Power board disconnected http://imgur.com/B4Bu3WX
Any and all help/info is appreciated
pogosa is offline   Reply With Quote
Old 06-20-2017, 06:18 AM   #2
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Default Re: Samsung UN55JU6700F No picture, no sound
The images are very dark. Could you upload pics via the upload system for badcaps?
Andrew F. Ali is offline   Reply With Quote
Old 06-20-2017, 06:37 AM   #3
pogosa
City & State: SATX
My Country: USA
First two pics are the backlight
Pic 1 main board connected to power board
Pic2 main board disconnected from power board
Pic 3 is with the panel off
Pic4 is where i noticed liquid marks
Old 06-20-2017, 02:37 PM   #4
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
I would be taking a close look at that ribbon cable for damage especially at the panel end of cable for corrosion and bad traces
__________________
dskall is offline   Reply With Quote
Old 06-20-2017, 02:43 PM   #5
pogosa
City & State: SATX
My Country: USA
I was able to wipe all of that dried liquid off the ribbon cable and didn't see any damage. The ribbon connects in under the front frame, not sure how to access that.
Edit: I had also disconnected the tcon board from the main board and the dimmed (or absent) backlight issue remained. Only disconnecting main board from power did the back light pop back on.
Old 06-20-2017, 05:49 PM   #6
dskall
dskall's Avatar
My Country: usa
Looks like you have backlights. Try disconnecting one ribbon cable to panel at a time and see what you get on screen.
Old 06-20-2017, 07:21 PM   #7
maxvalutech
City & State: forster nsw
My Country: australia
Line Voltage: 240v
Yes backlights but no audio so if the sound isn't turned down or muted and the audio voltage is there then you are looking at a main board problem, Inputs or Eeprom ?
maxvalutech is offline   Reply With Quote
Old 06-21-2017, 07:56 AM   #8
pogosa
City & State: SATX
My Country: USA
I pulled the tcon board and noticed discoloration in the back side.
Old 06-23-2017, 07:30 PM   #9
Nick's Tvs
City & State: Tucson Arizona
My Country: USA
Line Voltage: 120vac 60hz
I'm a: Professional Tech
That corrosion looks like you have a bad panel. Disconnecting half the screen unfortunately won't work on these newer models.
Nick's Tvs is offline   Reply With Quote
Old 06-23-2017, 07:36 PM   #10
dskall
dskall's Avatar
My Country: usa
Quote:
Why is that? Not challenging just asking
Old 06-24-2017, 05:10 AM   #11
Hamie
Hamie's Avatar
City & State: Scotland
My Country: UK
I'm a: Forum Junkie
Quote:
A lot of new TVs don't show an image on the side you unplug. Sometimes they only display lines on the side you unplug etc.
Had an LG recently where you unplugged the left side and right side showed a prefect image! And vice versa
Hamie is offline   Reply With Quote
Old 06-24-2017, 05:11 AM   #12
Hamie
Hamie's Avatar
My Country: UK
I'm a: Forum Junkie
That last post doesn't read quite right but you get the point.
Old 06-24-2017, 11:54 AM   #13
pogosa
City & State: SATX
My Country: USA
Which corrosion, the stuff on the back or the Tcon board itself?
Old 06-24-2017, 01:24 PM   #14
pogosa
City & State: SATX
My Country: USA
I did not include this originally but when powered on the standby light will blink 5 or 6 times.
Old 06-24-2017, 01:48 PM   #15
Hamie
Hamie's Avatar
My Country: UK
I'm a: Forum Junkie
Have you actually checked to see if the TCON is getting any voltage?
Old 06-24-2017, 03:12 PM   #16
pogosa
City & State: SATX
My Country: USA
I have not. I just watched ShopJimmys video on testing the tcon board. I'll check to see if there is power running to it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
