I have a bad vsx-1022-k pioneer that I obtained with a DC protect error and no power on. After finding reset code and testing channels the Front right had DC offset and bad transistor. Replaced transistor and emitter resistors and checked most components then reset idle current. The dc protect issue was solved , but still have no audio from any channels and no audio from headphone jack . When tuner is selected and tuned to station , I can trace audio from tuner to main board, through audio select board, through connector board , to the main digital board(hdmi board ) traced audio into IC 1401 AK4588VQ codec IC. Can't find audio out anywhere. Voltages to this ic and at all regulators appears ok according to service manual specs. Can't test the oscillator to this ic because my scope is too slow. Anybody have suggestions where to go next or is anyone aware of common failure on this digital board? I have significant electronics repair experience on Tv's , and often repair boards. I want to fix the pioneer and believe issue to now be on digital board. I also have other pioneers , such as vsx-1021 with similar no audio issue(amp is fine). I isolated it to digital board, but can't locate faulty component or solder BGA...
