Konica Minolta Bizhub C203
    hello
    I have problem with my BizhubC203 printer, when I print from PC page is printed ok but when copy or scan rezult is fuzzy leters and image.
    anybody had this problem with this printer?
    Re: Konica Minolta Bizhub C203
    No idea.
    Is the grease on the slide and worm gear drying out?
    Try opening the lid and watching if it slides smoothly.
    Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
    I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
    Some of the things I've fixed:
    60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
      You might want to cover the laser with a piece of paper so you dont blind yourself.
        could be problem in Fuser Roller?
          yep, that's toast.
            No need to ask if that is good or bad!
