Old 01-18-2006, 01:36 PM   #21
Rainbow
City & State: Slovakia
Default Re: Eizo 15" TFT Dim
If both lamps are not showing the same problem, try swapping the inverters/lamp cables.
Rainbow is offline   Reply With Quote
Old 01-18-2006, 06:03 PM   #22
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
Default Re: Eizo Flexscan L371 15" TFT Dim
that whole unit is mitsubishi.
i can tell by looking at the board pics.
if both tubes are running swap them on the inverter and see what it does.
had a mitsubishi in here last month that was sick at power up and improved slightly after 10 minutes of warmup.2 new ccfl tubes later it looks new again.
kc8adu is offline   Reply With Quote
Old 05-25-2006, 07:50 AM   #23
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
uugh i am heading for longest repair award.
can you tell me what to do about the rubber bits at the end of the tube, am i supposed to ease them back to enable desoldering of tube or is it going to be impossible? it is rather difficult.
also what kind of tape to use to secure wire to back of mirror, is normal electrical tape fine?
willawake is offline   Reply With Quote
Old 05-25-2006, 08:33 AM   #24
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
its ok, they pull back eventually and i did not use tape to secure wire.
Old 05-25-2006, 09:38 AM   #25
kc8adu
kc8adu's Avatar
My Country: U.S.A!
i carefully slice the heatshrink and peel it off.those white rubber blocks absob impacts and are hv insulation.also make sure the reflective film is still stuck to the metal.if it curls you get uneven lighting.
the heat does in the glue.
Old 05-25-2006, 12:25 PM   #26
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
good info, thanks! i will slice the heatshrink next time.
