Dell Latitude 5400 Bios password
    Re: Dell Latitude 5400 Bios password
    Hello, unlock my bios please, i forget password
    Motherboard - EDC41 LA-G891P
    Serial Number - HCPT2Z2
      Ok try and comment.
        Originally posted by aldopc View Post
        Ok try and comment.
        Thank you very much, everything works great!
          hi,i have a pickle here. i did many bios dump of 5400 lats and used the methods here to unlock them but this one i have will not allow me to dump. it has a 25b256DYIG smd bios
          and it halts every programmer i put it to. the ground seems to be the culprit or pin 4.
          i use direct wire soldered to the solder blobs then wire to the programmer.
          its a LA-G891P rev1.0 board with the 23VPXY2-8FC8
          is my bios chip fucked? it still turns on and allows me to get to setup.
            Hello, what programmer are you using?
              so far i used the common ch341 and the blue one v1.7 with voltage select. both freeze the neoprogrammer and the ch341 the moment i connect to usb. used the clip side then the headers. i disconnect the ground wire it unfreezes but then i cant read the chip.
                Did you desolder the chip from the board or are you reading it soldered? If so, you must remove it from the motherboard and read it out.
                  Hi. 5400 pass locked. please
                    i reinstalled the wires for a 4th time for some reason to see if i could try something diffrent and the ch431 acted normal and i was able to dump the firmware!
                    no idea what i did diffrent i suspect a witches spell for that day but thanks everyone.
                      It can be done much easier if you buy a probe on ali or other marketplace. just google "wson8 test probe".
                        Hello. I have a BIOS file that is experiencing issues. My Dell computer is getting quite hot even though it has just started up Windows and opened one Chrome tab. Can you help me modify this BIOS file? Thank you. Dell 5400 LA-G891P REV 1.0
                          La-g891p rev 1.0
                          svtag:8h573h2
                          thank you!!!
                            Originally posted by hieu13pro View Post
                            La-g891p rev 1.0
                            svtag:8h573h2
                            thank you!!!
                            Bios password or computrace or no display !!
                              My device is slow to boot up and becomes very hot quickly.
                                Try this clean me
                                  The BIOS is functioning, but there is no fan detected, indicating a fan error.
                                  My computer gets hot after using it for a while like this. Can you help me? Thank you
                                    Originally posted by essaadi View Post
                                    I found a solution to clear password from BIOS bin file (using "Hex Editor Neo"):
                                    1- Select the range 00045000 to 00048fff
                                    2- Select "Edit" then "Fill"
                                    3- Put "ΓΏ" in "Pattern" zone.
                                    4- Choose "Fill selection" then clic on "Fill" button.
                                    5- Save the new file.
                                    Enjoy!!
                                    NB : Always make copy of backup then work....
                                    Hello
                                    Need unlock 2 dell 5400 32Mo Bios
                                    I try this method on 2 Pc's, work well
                                    but not work on two another 5400
                                      Originally posted by Maxpower3 View Post
                                      Hello
                                      Here are your Unlocked files, I hope it works fine.
                                      In the first boot go to BIOS Menu, put your Service Tag, disable absolute (if it's enabled), save and exit. After that you can press ALT+F to exit MPM.
                                      Service Tag_1: 4YNG2Z2.
                                      Service Tag_2: HZKF2Z2.
                                      all donations are welcome,
                                        I try tomorrow
                                        just need 2 modifications here ?
                                        Perfect thanks
                                          I try tomorrow
                                          Perfect thanks
                                          You're welcome.
                                          Yes, I think this will erase the Password.
