This was sent in with liquid damage. I have 5v on the LCD detection filter, 5v in to the backlight driver, BKLT enable present, continuity along all these backlight traces, the voltage divider for the first transistor isn't being shorted by the driver. If I manually short it, I get 12V on the backlight because driver is still not telling the second transistor to switch power on the coil. I am stumped. LCD is definitely the right year, done NVRAM reset everytime and I see flashing folder with a flashlight. Replaced driver multiple times including at the same time as the mosfets. Using new drivers everytime from the same batch so I tried a donor board no change. I2C lines to the connector are good now, had to replace the connector but diode mode looks good now. TIA!
00163 No Backlight
Re: 00163 No Backlight
Current sensing resistor R7700 and traces to LED driver? VDDA and VDDP of the LED driver?
Feedback? I2C on the LED driver ok too?OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
R7700 is good, continuity is there to the driver for current sensing. 5V on VDDA and VDDD of the driver. Feedback is good, I2C lines are good. If I manually short R7702 I get 12V on the otherside of Q7706, but it still isn't getting switched/boosted. Driver has everything it needs but isn't doing it's job.
Soldering is good for sure?OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
And SMC_LID high?OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Tried another display assembly?
I'm out of ideas. If everything external to the LED driver is ok then it should be the LED driver itself that's causing the issue.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
