hi, i have a acer 5920g with a short.
when i plug ac, blue light are ok,but when press power on, lights turns on then immediately off.
if i check the most important pl resistor i see the pl16 related to ddr2 1.8volt is shorted both side.
in the schematic, page 36, i start from pl17 and 19v are on both side. then i go to pq39 and has 19v to drain and 0 v to gate and 0v to source.
i then moved to pu9. pin 1-7 0v. pin 8 = 5v and pin 9-10 0 volt.
pin 11-13 0v, pin 14 = 5 volt, pin 15 5v, pin 16-19 0 volt and pin 20 5 volt.
pr132 (related to pin 13 of pu9 has 3.4v from one side and 0 to the other.
dunno if ok but impedance mseasure -30.00 putting multimeter scale to 200k. inverting black and red of multimeter give me no value.
pc127, pc130, pc131, pr135, pc129 are all shorted.
where can i focus to spot the bad part of the laptop ?
tnx for all the help
for the schematic, just get it here:
http://www.google.it/url?sa=t&rct=j&...,d.Yms&cad=rja
PS: using a multimeter, if i press power botton, i get for 1 second voltage to all the most important part ; also on pl16 i have voltage output as 1.8 volt.
i have also noticed that after keep ac plugged for a while , Sio chip "U10" is getting a bit warm.... can be that the cause of all the problem ? maybe both this ic and also some short on ram circuit?
