How to make LVDS tester under 99 cents.
I feel a little cold out here........No problem.... Let's ...R..O..C....K....
Background music: John Lennon
https://www.youtube.com/watch?v=fi7gs9MuNbc
Instead of buy another junk...and all I want to know is...TV has LVDS signals ............YES or NO.......That's ALL..I don't care how many pairs.. LVDS signals TV has..........so...... that's find out..... HOW.......have ...FUN....
JUNK:
http://www.ebay.com/itm/LED-LCD-Pane...-/111081281772
http://www.ebay.com/itm/LVDS-Panel-T...-/271543998313
............................I hate all that cables..... i already burn two LCD screens by putting wrong LVDS cable......^%#%$&*%......
Figure 1 illustrates a typical LVDS transmitter. This transmitter consists of <<<<<<<<<a current-mode driver, which provides around 3.5 mA of current through the transmission lines of the differential pair. >>>>>>>>>>>>At the receiver, a 100 Ω termination resistor is used to match the impedance of the transmission line that connects the receiver to the driver. Closely matching the impedance of this termination resistor with the impedance of the transmission lines reduces harmful signal reflections that decrease signal quality. The termination resistor also provides a path between the complementary signal paths of the system. The high input impedance of the receiver causes the 3.5 mA current coming from the driver to flow through the 100 Ω termination resistor, resulting in a voltage difference of 350 mV between the receiver inputs. As the path for the current within the driver changes from one path to another, the direction of the current flowing through the termination resistor at the receiver changes as well. The direction of the current through the resistor determines whether a positive or negative differential voltage is read. A positive differential voltage represents logic-high level, and a negative differential voltage represents logic-low level.
The standard defines the input voltage range of the receiver, VIN, to be 0 to 2.4 V. This input voltage range is significantly larger than the range of expected voltages from the driver. This difference provides the ability to absorb and reject common-mode noise, noise that is present on both lines of the differential pair, and allow for offsets between the driver and the receiver
reference:
http://www.ni.com/white-paper/4441/en/
This is the one..... we gonna use....
a current-mode driver, which provides around /////////3.5 mA///////// of current through the ////////transmission lines ///////of the differential pair.
My first thread .....I don't know how to correct the misspelling on the top..
Should be:::How to make LVDS ....test.er...... under 99 cents.
JUNK:
reference:
