Gigabyte PSU's aren't the best but this is ridiculous.
Gigabyte exploding power supply
^If you have datasheets not listed PM meTags: None
Re: Gigabyte exploding power supply
And aside from being a meme, there is a high-rate of catastrophic failure of certain models of Gigabyte PSUs. If you have one of these in you're system you should probably replace it ASAP, and I'd personally avoid Gigabyte PSUs in general after this fiasco (not that I used them anyhow):
https://www.tomshardware.com/news/gi...exploding-psus
https://youtu.be/aACtT_rzToI
Originally posted by dmill89 View PostAnd aside from being a meme, there is a high-rate of catastrophic failure of certain models of Gigabyte PSUs. If you have one of these in you're system you should probably replace it ASAP, and I'd personally avoid Gigabyte PSUs in general after this fiasco (not that I used them anyhow):
https://youtu.be/aACtT_rzToICap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by stj View Posti'v seen the video's of people blowing them up with programable loads,
but has anybody seen a teardown yet where the problem is tracked down??
(because there's gonna be a hell of a lot of them on ebay cheap!!)
https://www.youtube.com/watch?v=Edv3UcJw0nk
The new version with all the changes made.
In theory, one can get a "bad" psu for less money or even for free and apply the changes in this video and make it safe, is this true?
