I have this preselector which i will use for optimising (hopefully) my reception of marine AIS signals which are on channels 161.975 MHz and 162.025 MHz. So this unit is peak tuned to 162 MHz.
The manual says it needs 10-15 Vdc and has current drain 10 mA.
So it says to solder postive wire to E1 which is ok. and the ground to the ground plane on the pcb.
where is that?
secondly it is apparently best to have this at the antenna (which in my case is 30m up). So any ideas for power? i guess some kind of battery, preferably not having to change/charge it too often. and umm taking into consideration that it will toast in the summer sun.
where is that?
