VHF Preselector
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    VHF Preselector
    I have this preselector which i will use for optimising (hopefully) my reception of marine AIS signals which are on channels 161.975 MHz and 162.025 MHz. So this unit is peak tuned to 162 MHz.
    The manual says it needs 10-15 Vdc and has current drain 10 mA.
    So it says to solder postive wire to E1 which is ok. and the ground to the ground plane on the pcb.
    where is that?
    secondly it is apparently best to have this at the antenna (which in my case is 30m up). So any ideas for power? i guess some kind of battery, preferably not having to change/charge it too often. and umm taking into consideration that it will toast in the summer sun.
  • kikkoman
    • Jul 2007
    • 691
    Re: VHF Preselector
    Ground is the large copper plane on the backside. You can also solder to the shielding of the cinch connector (doesn't matter which one, but preferrably the output) or one of the mounting screws, in case you mount the borad on a chassis and use metal screws and metal washers.
    10mA isn't that much - you could use a small solar panel. If the unit is sensitive to voltage fluctuations (clouds, sun etc) you can go the safe way and use a panel with a higher voltage - e.g. 20V nominal - and add a linear regulator.
    a boost converter would be easier, of course, but they usually produce ripple, which might be bad in this case.
    add a small R/C 12v lead battery in parallel, and you're done. if you adjust the regulator properly, you won't even need a charging circuit.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: VHF Preselector
      thanks. i was thinking about solar.
      • Harvey
        • Apr 2007
        • 264
        Re: VHF Preselector
        I'm surprised its not designed to have power up the coax feeder...
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: VHF Preselector
          unfortunately its not recommended as will affect rf performance
          • stretch0069
            Screwed Up Super Moderator
            • Oct 2003
            • 2662
            • oooo ess aaaaaaaaa
            Re: VHF Preselector
            yeah....i'd have to suggest the solar panel route as well. not sure how much sun you get there, but like kikkoman suggested....if there are a lot of cloudy days, get a bigger panel. bigger is always better, right???
            will's gonna suffer from panel envy now.
            "Its all about the boom....."
            Guns kill people like spoons made Rosie O'Donnell fat.
            We now return you to your regularly scheduled drinking.
            "Fear accompanies the possibility of death.....calm shepherds its certainty"
            Originally posted by Topcat
            AWD is just training wheels for RWD.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Re: VHF Preselector
              not to worry. i have a big antenna mast.
              solar is a bit expensive though i see (well, considering the premade kits) but yeah i would be interested to get into that also.
              range is very dependent on weather, in bad weather it can be quite bad only 30 nautical miles. i dont know if a preamp will have much effect in those conditions so it probably doesnt matter if it is off (solar not working) antenna will still work even if the preselector is unpowered.
              i really enjoy this stuff but pity nobody else in my area wants to join in.
              • 999999999
                • Sep 2006
                • 774
                Re: VHF Preselector
                Solar cell or not you probably need a battery as a solar cell can't be relied on in extreme weather, darkness, etc. Put a SLA 12V battery down inside and run a lead up to this. Then you can decide how you want to go about recharging the battery- manually, trickle charger from another power source, or with solar cells.
                Put some capacitance near the board, maybe a small ~ 10+uF 35V tantalum cap on the board at the power input. You could drill a hole where I show the X to hit the ground plane then + goes to adjacent hole diagonally to the left. You might need more, 30m is a fairly long run. Stay with solid caps due to weather, temp extremes.
                • Chaks
                  Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
                  by Chaks
                  TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
                  The specs says ...
                  High antenna efficiency 868MHz ISM Band
                  5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
                  The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
                  1. Should I Fix it with a glue.
                  2. Should I fix it with a double side adhesive tape
                  3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
                  12-09-2024, 11:06 AM
                • mkdj
                  Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                  by mkdj
                  Dear all,
                  I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                  I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                  Both N-Channel Mosfets: nothing odd
                  P-Channel MOSFET number 1:
                  source - drain : 117 kOhm
                  source - gate: 96 Ohm
                  gate - drain: 117 kOhm
                  P-Channel MOSFET...
                  08-20-2025, 06:08 AM
                • barry101
                  Apple 820-3662 VCore shorted to ground.
                  by barry101
                  Hi, Would appreciate some help.
                  I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                  Get charger light but no fan spin or chime. No liquid damage.
                  Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                  Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                  With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                  Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                  06-24-2025, 07:34 AM
                • reformatt
                  Lenovo NM-A921 (Yoga 900-13ISK2) dead
                  by reformatt
                  This machine has been in a few times with an intermittent fault of not charging. Motherboard is NM-A921 (https://www.badcaps.net/filedata/fetch?id=2051581)
                  So back again now, not working at all. Previously the adaptor had been replaced along with the DC charge port. This is one of these trapezoid shaped orange USB ports that Lenovo were using prior to going USB-C. It has 4 pins, but the DC connector jack on the PCB has 5 pins.
                  Fault presentation was the adaptor is only producing 5.2V, not 20V and this isn't reaching the input of the NVDC charger (PQ5/PQ6). There are 5...
                  02-05-2025, 05:24 PM
                • Leefreeman97
                  Diagnosing short to ground issue. pcb from an e scooter
                  by Leefreeman97
                  Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
                  09-19-2025, 03:33 PM
