Hi, My son sprayed cleaning solution (mixture vinegar and water) onto the tv screen which has dripped down and pooled into the bottom of the tv paneling. The tv was on at the time and when I came in it was a black screen and the power was cycling on every 5 seconds as if it was trying to turn on. I switched off the power once I noticed and took the tv apart. I was able to dry everything as best I could and I let it stand for 24hrs. I put it all back together and the tv works (unbelievable) but 2 solid vertical lines are permanently showing. I've had a look at some other threads but don't see anyone else having these same lines.
Can I get advice on what sort of repair or replacement part would be required?
Thanks a lot.
Thanks a lot.
