Re: WestingHouse 19" 19w4 LCD monitor- DAC-12M030
They are connected together because it is setup as the bridge drive.
Your Ohm reading does not make sense, for example: S1 -D1 (1) = 2.8K, S1-D1 (2) = 0.6k, that cannot be since D1(1) and D1(2) are connected together inside the IC, so the reading should be the same. The P-CHANELL MOSFET Drain is connected to pin5 (D1), and pin6 (D1) as you can see from the spec sheet.
Did you lift one end of the fuse as suggested to see if the power supply will work?
