I would like someone to tell me how to use a DMM to measure vrm voltage and cap voltage. Thanks ahead of time
how measuring voltage to caps and vrms
Re: how measuring voltage to caps and vrms
From the positive lead of the cap (i.e. backside of mobo) to any ground
From the (usually) middle leg of a MOSFET to ground, or more properly from the coil to ground...
Be caruful, if you short anythinng out bad things will happen, you could for example send +12v into the CPU..."The one who says it cannot be done should never interrupt the one who is doing it."
If you sent +12v into the CPU it would fry
A jumping temp is nothing too unusual, might just have been an incorrect reading from the tempsensor (which is fairly inaccurate to begin with)"The one who says it cannot be done should never interrupt the one who is doing it."
