Re: IC Number on DPS-286 AP/RDENCA336WJQZ Sharp power board
Great, so the Zener did show 2K when you test with Ohm meter?
7.5V should be OK or 12V 1/2W will be more than enough, as you can see in the application notes, there is no clamping Zener diode being used.
"Can i do without the zener? if it can light up, i suppose it is more for circuit protection and at most it will fry the opto or 264 should another surge occur?" Yes you can,that is correct.
