Re: IC Number on DPS-286 AP/RDENCA336WJQZ Sharp power board
S (Source) pins are connected to the primary circuit ground which is the Ground ref point.
BD 5.8V: This is normal.
ENUV (pin 4) .5V: There is problem here at this pin, minimum is 1V for the IC to be enable.
" I heard a sound and was slighlty startled. The screen came on when i put the meter between D and ENUV" That because the meter connections cause pin 4 to go high enough for the IC to get out off shutdown mode.
Please check the resistance between the ENUV pin 4 and S pin to see if it shows low resistance.
