HP lp3065 repair or part source.
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: HP lp3065 repair or part source.
    Originally posted by KhitSicker
    With the ohm meter on 2k the voltage goes up to ~1.09 then falls to .000 within 2 seconds.
    If you are measuring voltage with your multimeter set on 2k ohms, you are
    1) measuring it wrong
    2) not getting an accurate reading
    3) may potentially damage your multimeter
    You would need a very special multimeter in order to be able to measure 2k volts if your multimeter goes that high. Most multimeters only go to 1000V DC.
    --- begin sig file ---
    --- end sig file ---
    • KhitSicker
      • 25
      #42
      When I said 2k I was refering to the setting on the multimeter. This is the multimeter I have. On the OHM section i set the dial to 2k. You cant see it in the pic but the settings are 200, 2k, 20k 200k, 2m
      Not my pic by the way but its the same model mulri meter i have.
      • retiredcaps
        • Apr 2010
        • 9271
        #43
        You can't measure voltage with your multimeter when it is set to any ohm setting. Maybe you might a typo in post #40?
        • KhitSicker
          • 25
          #44
          well i guess it was ohms that i was measureing then. never used that setting before.
          • alexanna
            • Mar 2010
            • 1346
            #45
            Could you measure the on/off pin again but check the voltage, I'm interested in how much the voltage raises.
            I'm thinking PlainBill is asking about those three legged ICs, Hoping there is a possibility one may be a reset controller. Try to find a good magnifying glass see if you can identify the numbers on them.
            • KhitSicker
              • 25
              #46
              Do you want me to check the pins with or without the power on. and with the front panel plugged in or out of the logic board?
              • alexanna
                • Mar 2010
                • 1346
                #47
                Follow the instructions in post #22
                That’s explained in the last paragraph
                • KhitSicker
                  • 25
                  #48
                  The result is the same as when i tested it the first time. no voltage change on any of the front panel pins when the power is on and the button is pressed. This is with the black probe in a ground screw and the red probe testing the front panel pins on the logic board.
                  Now I was able to identify the ground pin and when i am testing with the ohm meter with the black probe on the ground and the red probe on the pin ive identified as the front panel there is a change when the button is pressed.
                  for shits and giggles i tested for voltage on the ground pin and the "on" pin with the power on and the voltage is 0 both at rest and when the button is pressed.
                  • alexanna
                    • Mar 2010
                    • 1346
                    #49
                    Well then there's a problem with the voltage not changing,
                    Unfortunately I have a pain level of 10 and a concentration level of 0.
                    I can suggest simple things to check but I'm unable to walk you through it.
                    Hopefully someone else will jump in and walk you through the tests.
                    • KhitSicker
                      • 25
                      #50
                      ive heard of people baking electronics in the over .. 385 degrees for 8-10 min to reflow soldier joints and the like. is there any valadity to that and does anyone reccomend I try it?
                      • alexanna
                        • Mar 2010
                        • 1346
                        #51
                        OK now find those same pins on the logic board. See if the voltage changes at the logic board connector, there is a possibility of a broken wire.
                        • KhitSicker
                          • 25
                          #52
                          Thats is where I tested them.
                          They did twitch when I tested them with the Ohm meter setting but not when I tested for voltage.
                          • KhitSicker
                            • 25
                            #53
                            Should I just give up on this and part out the monitor at this point? Or does anyone have a sorce for lcd logic boards.
                            • rswails
                              • Jul 2013
                              • 7
                              Did you figure this out? What is the conclusion? lol I just read this whole thread and didn't like the ending!
                              • paboman
                                • Jul 2014
                                • 1
                                • Italia
                                #55
                                Im also interested in the ending.
                                thx!!
                                • t256
                                  • Jul 2014
                                  • 2
                                  • fdgfd
                                  #56
                                  Replace SMD fuse F1 (2A) on the PCB LCM
                                  • zvaniel4o
                                    • Feb 2014
                                    • 12
                                    • US
                                    #57
                                    Hello guys!! My father in law has the same monitor. The unit was not powering on, anyway after disassembling I noticed that some capacitors were having a loose solder connection, I re-soldered them and now the unit works. There is a one issue though - it has vertical lines. What can the reason be, damaged LCD, damaged LCD controller, power supply, does anybody have a clue from where to start?
                                    • edugimeno
                                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                      by edugimeno
                                      Hi There!
                                      I'm trying to help my friend who owns a restaurant be just bought.
                                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                      09-05-2024, 09:34 AM
                                    • G-Sting
                                      iPad Pro A1876 SHORT Part Identify Help Needed
                                      by G-Sting
                                      So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                      So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                      i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                      SO My main concern is what part should i order what should i search the name for ?
                                      on Ipad...
                                      05-15-2025, 09:30 AM
                                    • Lvsitano
                                      Asus X532FL 3.2V at source and gate
                                      by Lvsitano
                                      I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                      First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                      I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                      First...
                                      06-26-2024, 02:13 PM
                                    • Yanleb
                                      Panasonic part number in service manuals
                                      by Yanleb
                                      In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                      This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                      For an example, look at the attached PDF.
                                      Do you have a way to cross reference the Panasonic part number with the actual part number?
                                      Thanks....
                                      07-03-2023, 08:16 PM
                                    • FreakyMex
                                      Trouble to identify part (Lunii screen) for replacement
                                      by FreakyMex
                                      Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                      I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                      02-17-2025, 01:16 AM
