Need help, HP omen ax236tx , no boot capslock blink 5long 3 short
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Need help, HP omen ax236tx , no boot capslock blink 5long 3 short
    Sorry, PQ1002 gate voltage is correct and your pq1004 is working. PQ1003 Voltage on PIN 4?? This is the gate i was looking at. Do you have same spare charger IC??
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      Hi , Thanks for help
      I did not understand how PQ1002 is working as at Gate=18 volts which should be low as 7v or 9v for P type mosfet with source having 19volts?
      In schematic it is written do not add test pad on bATdischarge_gate that is why i did not check voltage at pin 4 gate .
      if it is save i check . let me know
      No i do not have a spare charger IC.
      One spare motherboard is Sony Vio SVE11AW which has charger IC different.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Pq1003=pin 4 gate= 0 volts
        charger ic reading with power adapter in
        Charger ic
        vcc of charging ic pin 20= 19 volts
        PC1028 vcc of charging ic= 19 volts
        PR1026 vcc of charging ic= 19 volts
        charging ic pin 6 reg6v= 6volts
        charging ic pin 5 ACIN/ACPRES= 0 volts
        charging ic pin 3= 1 volts
        charging ic pin 1= 3 volts
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Charging IC's pin 1-2-3 should have shown same voltage-so do re check your measurements. Pin5 must be stable 3.3V and this signal goes to your kbc controller. Do check resistance on those pins. Pin 1-2 as well as pin3 should be 19V but you are not getting it as pin4(Gate) of PQ1003 is not opening. If PQ1003 is not shorted, very likely charging IC will need replacement.
          PS:PQ1002 gate voltage at 18V is correct.
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            should i check these voltages with RTC battery IN and power adapter IN although there is no light on charging port of motherboard?. please do reply so i check measurements again
            Yes PQ1003 has 0 volts on gate. if you have time what will be state of ACIN signal in case PQ1003 is working?
            In my other previous motherboard this charging IC had the fault so it does occur to these ICs
            resistance measurements without adapter plugin and RTC battery out???
            Thanks for your time
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #26
              01.Voltage can be measured with rtc battery in. Adapter has to be connected , else what you are going to measure.
              02.ACIN should be 3.3V if PQ1003 is working but there are other conditions which has to be met like charging ic requirements, kbc controller .
              03.Resistance has to be measured ALWAYS without any power.
              Hope that clears your queries.
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                #27
                Thank you , will check and update in few minutes
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  #28
                  charging ic PU1001
                  charging ic pin1= 0.01 ohm (beeps when check in contuity mode with grnd)
                  charging ic pin2=0.01 ohm (beeps when check in contuity mode with grnd)
                  charging ic pin3= 4.06 ohm (does not beeps when check in contuity mode with grnd)
                  resistance measurement for coils as well at 20kohm range selected DT-266 unity clamp meter(only available)
                  PL1001= show some values 19.7 then stable at L means out of range
                  PL2001= show some values 16.7 then stable at L means out of range
                  PL6001 = 0.00 ohms stable
                  PL2004= show some values 19.2 then stable at L means out of range
                  PL3001 = 0.30 ohms stable both sides
                  PL4012= 0.00 ohms stable
                  PL4003= 0.01 ohms stable
                  PL4004 = 0.01 ohms stable
                  PL9017 = 0.29 ohms stable
                  PL9010 = 0.08 ohms stable
                  PL9005 = 0.03 ohms value fluctuates from 0.20
                  PL9004 = 0.01 ohms stable
                  PL9001 = 0.01 ohms stable
                  PL4008= 0.00 ohms fluctuates to L out of range
                  PL4010= 0.01 ohms fluctuates to L out of range
                  voltages on charging ic again:
                  pin20 vcc=19v
                  pin=1,2,3,4,5= 0 volts
                  pin6= 3v
                  pin 7=0v
                  pin8= 0 ,1 volt fluctuating
                  pin9= 0 volts
                  pin10=0 ,1 volts fluctuating
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    #29
                    Hi Need Help Please,
                    In addition to above measurements some more without adapter not plugged but RTC battery still in
                    PQ1003 in diode mode = source to drain no sound OL ( red probe on drain pin5 and black on pin2)
                    PQ1003= source to drain Buzzer sound when black probe on Drain and red probe on source pin2)
                    while PQ1002 gives no buzzer
                    PR1008 = Big Fuse = when check for continuity gives Buzzer/beep
                    Charging IC BQ24738H pins 1 ,2 both pins(CSIN,CSIP) are giving beeps with respect to ground check in continuity mode.
                    PL3001= 1.2vsus supply coil condition is de coloured with respect to other coil ( little shiny spots not grey color anymore at edges)
                    PL6001= 1vs5_s2 supply coil condition is de coloured with respect to other coil ( little shiny spots not grey color anymore at edges)
                    Last edited by piernov; 10-21-2020, 12:55 PM. Reason: remove full quote of previous post
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      Your +PRWSRC or what we commonly call as B+ line is shorted to ground. Remove PR1008 and see which pad is shorted to gnd and then inject 1V on the shorted pad of PR1008 to find out what is getting hot. Dont inject more then 1V , else SOC may be killed if there is shorting on high side mosfet. Better check physically all high side fet for shorting also before injecting voltage.
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        #31
                        physically all high side fet means PQ1004, Pq1002 etc +VA side mosfets or something else?
                        • stingerchamp
                          • Sep 2020
                          • 425
                          • Pakistan
                          #32
                          Hi, I have a question , is there a way to check MOSFETS working 100 percent sure while mosfets are still on board.
                          Most DMM(Multimeters) will not show forward bias voltage (0.5---0.6v) while board power off . Multimeter shows only values at continuity mode of DMM
                          i-e 150 to 396 etc (it shows resistance or volts)?. what is this value sorry for being dumb.
                          . High price DMM show even voltage values as mentioned above ( 0.5--0.6v) but most cheap DMM show only values which i mentioned above( 200--400).
                          Secondly Is it save to plug in power 19v power on motherboard while PR ( big fuse) is not present , i do not have DC power supply and will take time to get one.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #33
                            If you dont have Dc supply, dont mess with it as it'll be practically impossible to found shorted component. Learn basics of laptop repair first. We cant teach you here.
                            • stingerchamp
                              • Sep 2020
                              • 425
                              • Pakistan
                              #34
                              Hey,dont be so rude ,have a cup of tea.
                              In this forum beginner guide ,It is written choose option 2 if you want to learn about fixing laptops and i am in situation no 2.
                              https://www.badcaps.net/forum/showthread.php?t=88758
                              if you do not want to help do not reply, other members will help if you do not want to help
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                #35
                                I'm not being rude, rather telling you what is in your best interest. Without knowing the basics you will end up damaging mb rather then repairing it specially with SOC mb's. this forum cant teach you basics even though you can learn a lot from here provided you know the basics. Anyway, lets others help you.
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  #36
                                  Problem resolved, vccsa coil supply was missing 0.95v.
                                  Replaced pq4012 and laptop working
                                  • questore
                                    HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
                                    by questore
                                    Hello everyone.
                                    Someone brought this poor hp in.
                                    All power rails had normal resistances so i turned it on. Instant power cutoff...
                                    First mosfet was shorted so replaced it...
                                    After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
                                    After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
                                    Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
                                    08-25-2025, 10:09 AM
                                  • Tom_x
                                    HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
                                    by Tom_x
                                    I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
                                    HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
                                    Now with blinking capslock:
                                    All voltage present on big coils, except +VCCGT (i don't know this need for booting)
                                    I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
                                    DDR4 ram is ok, tested on other laptop
                                    WLAN and SSD removed,...
                                    07-20-2023, 10:10 PM
                                    HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) OMEN i7-6700 Specification for Upgrade or Repair
                                    This specification for the HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                    09-12-2024, 03:44 PM
                                    HP OMEN OMEN by Desktop PC - 870-117na OMEN 870 i7-6700 Specification for Upgrade or Repair
                                    This specification for the HP OMEN OMEN by Desktop PC - 870-117na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-117na boardview and OMEN OMEN by Desktop PC - 870-117na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    HP OMEN OMEN by Desktop PC - 870-128na OMEN 870 i7-6700 Specification for Upgrade or Repair
                                    This specification for the HP OMEN OMEN by Desktop PC - 870-128na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-128na boardview and OMEN OMEN by Desktop PC - 870-128na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
