T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
  • jacobk1508
    • May 2016
    • 69
    • Viet Nam
    Re: T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
    Originally posted by volinakis
    you have to power the board before reading EC
    I have already powered up the motherboard. The problem I'm having is reading EC data indicates empty file, it's not a problem of not reading EC
    • volinakis
      • Jan 2021
      • 2874
      • N/A
      check again wires, maybe you reversed TDI with TDO. And choose MEC1633_256k for RT809H
      • jacobk1508
        • May 2016
        • 69
        • Viet Nam
        This is the output I get when I try to read the MEC1663, I believe I followed the instructions correctly, the JTAG connection wires are correct.
        • jacobk1508
          • May 2016
          • 69
          • Viet Nam
          I tried all the options in the programmer's list, MEC1633#ISP, MEC1633#256K etc.
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            happened to me the same at 1st laptop I unlocked with RT809H (chip may be damaged...). Read this maybe will help you. also, do not wire #RST.
            https://www.badcaps.net/forum/showpo...&postcount=234
            • mily.gawel
              • Aug 2018
              • 42
              • Polska
              #26
              Hello. I have a problem with T14s and EC Mec1633-BA0 reading. I'm using SVOD4, after changing the place of the resistor and connecting the JTAG
              MEC IDCODE: B1240020
              Device ID: 0
              Device Revision: 0
              Device Status: 0
              Flash Status: 0000000000
              Boot Block in not protected mode
              Flash Configuration: 0000000000
              Start reading: 11.08.2023 08:00:39
              End reading: 11.08.2023 08:00:40
              CRC calculated 1D0F
              CRC stored 0000
              Read OK
              But the read dump is empty, it seems to me that I connected the JTAG correctly, with the same connection in x390 it reads EC correctly. Does anyone have an idea?
              • reverb
                • Aug 2023
                • 3
                I'm facing the same problem as rumpumpel on a T14 Gen1. I successfully dumped the MEC with MEC1633#ISP setting. However, after reflashing there is no fan, no LED, nothing. After having a look at the dump it seems like the last bytes got cut off and I should've dumped it using the 256K option. But as I don't have a second device, now I don't have access to the full image anymore.
                Would someone mind sharing their MEC1633 dump with me or has any idea where I can find one?
                • reverb
                  • Aug 2023
                  • 3
                  Okay I fixed it by flashing the MEC1633 image of a T490 which is also 256kb. I found it in this post: https://www.badcaps.net/forum/showpo...&postcount=170
                  Now everything works fine and the supervisor password is indeed gone.
                  • ordinateur
                    • Mar 2020
                    • 85
                    • Monaco
                    #29
                    Nice explanation and tutorial by coolshrimp regarding these Lenovo laptops. I have some ambiguities on how do I do this whole procedure with just Keyboard connector cable and with the least possible soldering (without JTAG). As I have the full set of RT809H when I bought it, I think I may not miss a single item because when I bought it I acquired the biggest set with over than 50 parts.
                    I saw RethoricalCheese used just the Keyboard connector to do the job, but I am not understanding the concept of Pull Up - Pull Down resistor, 10 K, and where do I solder that?
                    P.S.
                    Just noticed on the picture attached the description: Resistor Below goes here or place a 10K resistor. Move resistor below to the above position to enable R/W
                    Will be trying as coolshrimp described
                    In my case I Have Thinkpad T14 Gen1 AMD version
                    thanks in advance for such a great and helpful forum
                    • volinakis
                      • Jan 2021
                      • 2874
                      • N/A
                      #30
                      P.S.
                      you can't use keyboard connector with RT809H, only with svod3-4 or SAS programmer. "Pull-up - pull down" resistor have to move it to enable reset of the EC, otherwise you can't be able to erase it and write it. Are you sure Thinkpad T14 Gen1 AMD version has MEC1663 as EC?
                      • rbvndonh
                        • Mar 2021
                        • 162
                        • B
                        #31
                        Thanks for tutorial
                        • mily.gawel
                          • Aug 2018
                          • 42
                          • Polska
                          #32
                          what should be the size of the file after reading, 192 KB or 256 KB? I read 256KB correctly. After deleting the file, it reads 256 KB, I checked the MEC and it is empty and the laptop shows no signs of life. After 5 minutes, I program it again, move the resistor and the laptop starts up, but the password still remains.
                          • Dido210
                            • Sep 2020
                            • 9
                            Does anyone know if this process can be done with a EZP2023+ programmer?
                            • volinakis
                              • Jan 2021
                              • 2874
                              • N/A
                              #34
                              you can start the motherboard connected to a monitor via HDMI without moving back the resistor to check if password is gone. Did you ERASE the EC before writing back the dump file? And you have to disconnect all power sources, including programmer, for 2-3 minutes after you erased EC.
                              I always choose MEC1336_256k to read EC with RT809H and extract EC file from bios update to write it back and worked all times. Also read
                              https://www.badcaps.net/forum/showth...light=MEC+16xx
                              and you'll find useful infos.
                              • fr3man
                                • Jun 2022
                                • 3
                                • n/a
                                #35
                                Does it work with rt809f? I cannot erase, read or write, because chip gets identified as OxCDCDCDCD
                                • fr3man
                                  • Jun 2022
                                  • 3
                                  • n/a
                                  #36
                                  When i try to identify, i am getting this.
                                  Any advice?
                                  RT809F
                                  Chip ID: 0x00FF0406, the device is not found in the corresponding partnumber, you can click "OK", and then manually add this partnumber with their ID, or copy this message content and chip partnumber, and feedback to the technical support forum: WWW.IFIX.NET.CN o
                                  OK Cancel
                                  • jm801
                                    Banned
                                    • Apr 2020
                                    • 123
                                    • monterrey
                                    #37
                                    someone will have the configuration of MEC1723
                                    To be able to add it to my programmer I have the vertyanov but that one doesn't come there so I can program it​
                                    • wangbreeze
                                      • Jan 2024
                                      • 19
                                      Thanks for the work and sharing. If I read it correctly, we can add another 10k resistor to enable JTAG? Thought it’s easier to add and remove than to move the small resistor around. Thank you.
                                      • wangbreeze
                                        • Jan 2024
                                        • 19
                                        Thanks for the tutorial. I have successfully removed the password. However, I cannot seem to modify the settings such as setting a new SVP password. It shows error “write protected”. Anyone has similar issues? Thanks.
                                        • wangbreeze
                                          • Jan 2024
                                          • 19
                                          Reflashing BIOS obtained from Lenovo website resolved the issue. And the board serial number (B0) can be found from a sticker on the motherboard. It is much longer than the 11 character long serial number found from BIOS information screen but that’s what the Lenovo maintenance utility takes.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • farouk_1994
                                            T14s NM-C891 MEC1663
                                            by farouk_1994
                                            Hello i need T14s NM-C891 i/o MEC1663 bin file and bios thank you.
                                            04-12-2023, 07:10 PM
                                            Lenovo ThinkPad T14s Notebook T Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad T14s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T14s boardview and T14s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-07-2024, 07:20 AM
