need bios dump dell latitude 5420 (cpu 11th)
  • hoaca388
    Badcaps
    • Jan 2022
    • 12269
    #341
    Re: need bios dump dell latitude 5420 (cpu 11th)
    Originally posted by darckreign1984
    i discover that ut3 chip its verry hot.
    That means there is a short on the board.
    • adrenadosoul
      • Nov 2022
      • 6
      • Chile
      #342
      Originally posted by HTR-Informatique
      I have a Dell Latitude 5420 stuck on the Dell Security Manager message on startup, I can't do anything.
      Here is my BIOS and what I assume is ME (32MB for BIOS and 1MB for ME).
      If someone could remove my BIOS password for me so I can reflash it afterwards.
      It's an 8FC8.
      ST/SN: JSJW5D3
      Thanks.
      How you extractec both files?
      I have CH341 programmer and when i try to dump it only dump one file with 1mb...
      how i can get the other?
      sorry my bad english
      • lapfix
        • Mar 2020
        • 2756
        • my workshop
        #343
        Search at your motherboard you will find another chip write on it 256 or 128
        • adrenadosoul
          • Nov 2022
          • 6
          • Chile
          #344
          thanks for your answer. I'm going to look for this other chip on the board. would you allow me another question? My computer is not turning on, nothing happens and I can't enter the bios either. what file here on the forum can i use to reset the bios without losing my original service tag and my warranty?
            • 21679
            If its under warranty get it repaired .If you start messing with the bios and it doesn`t work you might not be able to get it repaired,if you have broken any warranty seal, and dell will know youve worked on it. The other chips are WSON type, if you`re using a SOP8 clip ? it won`t work and you could cause further damage
            • adrenadosoul
              • Nov 2022
              • 6
              • Chile
              #346
              I already used a file here in the forum on page 7 that says cleared me.. And now what do I do?
              Do I need to get the bin and go to the programmer again? mine is the gdf40 la-k491p rev 3.0 a02 winbind 25q80dvsig dump file 1mb i already broke seals when I opened laptop
              Please help me and I'm sorry for bother you
              I know I knew member here and not contributed so much
                • 21679
                Did you make a backup of the 25q80dvsig chip,did you erase it or try programming to it ? ,it is not the bios chip as already pointed out by lapfix
                • adrenadosoul
                  • Nov 2022
                  • 6
                  • Chile
                  #348
                  at this moment, this chip is blank. I read it with ch341 and there is no data recorded inside the chip. I remember I deleted it and I didn't back it up.
                  I messed up huh?
                    • 21679
                    I messed up huh?
                    yes you messed up but don`t worry. There might be a 25q80dvsig 1MB file posted somewhere on the forum, and if there isn`t then just ask the next member who posts a request in this thread if they would kindly post it.What is the marking on the motherboard next to the chip, U? something
                    • adrenadosoul
                      • Nov 2022
                      • 6
                      • Chile
                      #350
                      I understand friend.
                      can you please guide me to repair my bios?
                      I already understand that this chip is not the bios, when I find the bios chip and can I get any bin here on the forum and use it?
                      having the same specs as mine?
                      • adrenadosoul
                        • Nov 2022
                        • 6
                        • Chile
                        #351
                        Is it possible to program my WSON type bios chip withou a socket?
                        Directly on the board?
                        Is there an adapter to not need to unsolder the chip from the board?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12269
                          #352
                          Possible
                          • layad
                            • Nov 2011
                            • 244
                            #353
                            dell latitude 5420 PCB: LA - k491p rev 2.0
                            hi
                            dell latitude 5420 PCB: LA - k491p rev 2.0, bios dump is damaged anyone can help me fixing it please
                            • hardware1
                              • Sep 2021
                              • 2946
                              • N/A
                              #354
                              Re: dell latitude 5420 PCB: LA - k491p rev 2.0
                              Originally posted by layad
                              hi
                              Here's your new file, try it and let me know the results.
                              Service tag: 8TSWPN3
                              all donations are welcome,
                              • folbins
                                • Apr 2022
                                • 1
                                • BELARUS
                                #355
                                Please help unlock the BIOS with a password
                                • hardware1
                                  • Sep 2021
                                  • 2946
                                  • N/A
                                  #356
                                  Here's your Unlocked file.
                                  • sanjay123
                                    • Aug 2018
                                    • 5
                                    • india
                                    #357
                                    Re: need bios dump dell latitude 5420 (cpu i5 11th)
                                    please unlock
                                    • lapfix
                                      • Mar 2020
                                      • 2756
                                      • my workshop
                                      #358
                                      Originally posted by sanjay123
                                      please unlock
                                      Try and give Feedback
                                      • sanjay123
                                        • Aug 2018
                                        • 5
                                        • india
                                        #359
                                        thanks bro
                                        • judamex
                                          Active Member
                                          • Jan 2021
                                          • 186
                                          • Mexico
                                          #360
                                          Can you help me to unlock this BIOS?
                                          try another file, but now it turns on and off and sends the display test, white, black, red, green, blue, black screen, restarts.
                                          • mirjana
                                            EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                            by mirjana
                                            I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                            The embedded controller is MEC5107-LJ (UE1).
                                            The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                            I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                            If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                            Thank you in advance!...
                                            07-16-2025, 12:55 AM
                                            DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                            09-06-2024, 03:21 PM
                                            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                            09-06-2024, 09:23 AM
                                            09-06-2024, 08:47 AM
