Hi, I wanted to share a working bios for HP 250 G7 BoardID EPK50 LA-G07EP Rev 2.0 / CPU i3 8th gen. I Hope it helps someone.
Tags: None
Every donation made will go towards server fees and maintenance costs.Comment
Re: HP 250 G7 BoardID EPK50 LA-G07EP Rev 2.0
Dear, I tried to program the bios, but after programming, if I read chip there are a some differences. I tried to turn on laptop but still in black screen. Also I bought two new chips. Still the same. What could be happening? Thanks a lot.
images:
https://ibb.co/LRG6nYp
https://ibb.co/BL17hNM
post the backup copy of the original laptop bios ...Dear, I tried to program the bios, but after programming, if I read chip there are a some differences. I tried to turn on laptop but still in black screen. Also I bought two new chips. Still the same. What could be happening? Thanks a lot.
images:
Thanks for your answer.
I upload my backup, but I think it is also damaged...Attached FilesComment
the posted bios is corrupt ... try this ...Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thanks Sir. Dont know why, when I program chip, get gorrupted. Im using CH341A programmer with Colibri (also I tried with other sofware). I also tried with new replacement chips. What can I do?
Best regards
EDIT: I tried now with NeoProgrammer V2.2.0.8 and it was programmed well!! Now laptop is turning on, fan spins, but screen keep in black. If I use phone torch I can see screen in black for some seconds, and then laptop restarts over and over.Last edited by periquitodel; 08-24-2021, 03:49 AM.Comment
i am posting my old bios which i am facing no display, can someone fix it.
Thanks in advanceAttached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Best regards
I have same problem.. Did you fix it? Please share with me the solution.Comment
Buy the CH341A programmer, download NeoProgrammer V2.2.0.8 and install it. Use CH341A read your bios chip, save it and post it here.Originally Posted by periquitodel View Post
Best regards
EDIT: I tried now with NeoProgrammer V2.2.0.8 and it was programmed well!! Now laptop is turning on, fan spins, but screen keep in black. If I use phone torch I can see screen in black for some seconds, and then laptop restarts over and over.↵
https://www.badcaps.net/donateComment
same problemAttached FilesComment
HP 250 G7 Notebook PCAttached Files↵
this bios is from Hp 15-DA0010la mainboard EPK50 LA-G07ep OK 100%Comment
the same problem with the epk50 la-g07ep bio, wikladivaya dump, help you pleaseAttached FilesComment
HP Notebook - 15-da0010la. Try two files.↵
by justice171Hi everyone,
I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
Thanks in advance!
by ngngocson113hi everyone
i need bios asus tp301uj ( "uma " vga share)
my mainboard doesn't use vga chip and it uses vga together with cpu.
I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
thanks everyone....-
Channel: BIOS Requests ONLY!
by parmeshwarPleas share ASROCK Q370M Schematic and Board view if available
07-18-2025, 02:01 AM -
by amitswamiPLEASE BIOS PASSWORD REMOVE
HP 15Q-DS0010TU
SN# - CND84677CP
ProdID - 4TT19PA#ACJ
BOARD NAME - EPK50 LA-G07EP REV 2.0...-
by johnbetonHello,
Working on a board HP EPK50 LA-G07EP. Owner tried to replace LCD display without disconnecting battery. Afterwards, the notebook turns on for a few seconds and shuts off.
Mainrail looks fine, battery charges. I have +5VALWP, but that's it.
I measure short to ground (0.03Ohms) on +3VALWP and +1.0V_PRIMP.
Injecting 1v at 3A on PL1001 and PL302 only slightly warms up the cpu after several minutes. - Loading...
