Got this try and post back if it works + schematics
hp DM1 NM9 - Schematic
by DatahoarderHP EliteDesk 800 G2 MINI/DM (1L PC)
I have 40 of these units. All of which i tried to update bios with HP's utility got bricked. All of them were bios password locked, i used the jumper thing to reset it. Couple updated bios, one of which worked fine for _ONE_ boot. Second is now mixed with rest, i don't know which it is specifically so have not retested it.
All had some MESpilock failed errors on (my) first boot of the unit.
Photo: https://cdn.discordapp.com/attachmen...018_220853.jpg
by tay147895412Hi, I have an HP EliteDesk 705 G1 mini.
Model: HP EliteDesk 705 G1 Desktop Mini
Processor: AMD PRO A8-7600B
Motherboard PCB Marking: "APCB M3 94V-0" / "NPGC N-150TL"
BIOS Chip: Winbond 25PE20VG (2 Mbit SPI, 3.3V, 8-pin SOIC) and MX25L6473E 64Mbit (8MB), SPI NOR, 3.3V, 8-pin SOIC
Could someone help me with my bios , request:
unlock MPM/DMI with a BIOS patch/mod , dc tay42069 if someone could help me pls
Im gonna leave down below my working bios, if someone could mod it so it has the mpm...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM - Loading...
