Abit VP6 with bad caps - The 'Singing' VP6
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Ok, a VP6 with bad caps is definitely no surprise to anyone... However, this one was a really strange one... I purchased it for almost nothing, the owner not knowing what was wrong with it (although, I had a good idea)... She told me it just froze one day, and that was it... It never POST'ed or worked again after.
    This board would not POST upon arrival. Infact it did some goofy things I've NEVER seen any motherboard ever do! Upon power-up, I could hear a faint high-pitched 'whistling' coming from the board... I thought it might be one of the bad capacitors venting, although, it didn't resemble this... If I removed power, the whistling immediately stopped. Typically a venting cap will gradually silence over a few seconds when power is removed... When I reapplied power, it immediately started again... HEH, the board was singing tunes to me... I didn't have a PC speaker connected, and there were no fans attached to the board. I only had a heatsink on the CPU just for a quick test. This VP6 is definitely one of the worst VP6's I've seen with bad caps. Every single 1000uF had vented, and every 1500uF except one had vented. The one that didn't vent real 96pF on my Sencore LC102, so it was definitely toast, despite the fact it didn't pop like the rest.
    While I was never able to isolate or actually identify the whistling I heard, I did recap the board, and it was 100% successful, replacing 23 caps. The whistling sound was cured also. I did some modding with the new capacitors, testing different values... This yielded some interesting results that even surprised me! The results are coming soon! These results will be posted in the Custom Mods and Tweaks category in the forum.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    the whistle was one of the converters running into a short.
    not unusual.
    some will scream at you and some just tick like a timebomb.
    one of the bad lytics had gone s/c.
      Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
      by momaka
      I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
      For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
      https://www.badcaps.net/filedata/fetch?id=3591771
      https://www.badcaps.net/filedata/fetch?id=3591772
      It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
      https://www.badcaps.net/filedata/fetch?id=359177...
      03-12-2025, 03:42 PM
    • eryjus
      Heathkit IO-4205 Power Supply Caps
      by eryjus
      First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
      I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
      I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
      05-10-2023, 11:21 AM
    • Paxman_Swede
      Identifying caps on an old Zoom 9000
      by Paxman_Swede
      Hello!
      I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
      The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
      I have studied the board and...
      01-14-2025, 09:51 AM
    • captain150
      Help with switching power supply caps
      by captain150
      I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
      I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
