vestel 17mb95s repair hint
  • steviewonder
    • Dec 2013
    • 183
    • england
    A common issue,as many will know,is firmware corruption on these,and it's variants.
    After flashing,you may find that when cold,it will revert to the dreaded blinking light scenario.Many have suggested it's a worn-out flash chip-This is not the case.Its caused by a Multilayer ceramic cap,fitted above C137,directly above the letter C.simply remove it.
    Problem solved!,one for the book of notes!
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • France_53
    Vestel tv, how to flip the image?
    by France_53
    Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
    05-12-2024, 05:22 AM
  • FlailingEngineer
    Help with Bush Tv (Vestel 17mb95m Mainboard)
    by FlailingEngineer
    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
    05-31-2023, 06:52 AM
  • lberkani
    Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
    by lberkani
    Hi everyone,
    I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
    The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
    The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
    I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
    - Toshiba 65UL2163DG
    - Vestel 17MB180E mainboard
    - Panel VES650QNTX-N2-N42
    - Version V1.28.100.0 if available
    If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
    11-11-2025, 12:37 PM
  • hazi12
    Vestel main board 17MB140TC
    by hazi12
    Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
    Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
    I can send a dump....
    10-01-2025, 01:28 PM
