toshiba regza no picture
  • sienoki
    sienoki
    • Jan 2012
    • 314
    hey guys n gals..ive a toshiba 32AV555D that will not display any picture..it has audio & the backlights are on..it will display programme guide & menu etc but no picture.. ive tried downloading schematics from electrotanya but no pdf in rar filesthx
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: toshiba regza no picture
    does it play a dvd etc through scart ok
    • sienoki
      sienoki
      • Jan 2012
      • 314
      Hi fella..no picture displayed through scarts only audio aswell..thx
      • sienoki
        sienoki
        • Jan 2012
        • 314
        these are best pics as no natural light..heres 1 of t-con..is the smd with 202 the fuse if so that tested ok on continuity..thx
          If it displays the OSD overlay - i.e. menus - then the problem is with the main board.
          Check all LDOs on the main board, and any fuses you can see.
          • sienoki
            sienoki
            • Jan 2012
            • 314
            Cheers tom..will start looking over mainboard..thx fella
            • sienoki
              sienoki
              • Jan 2012
              • 314
              I cant find any schematics for this mainboard & there is no available replacement so im gonna have to put it away till i get some more time as i dont know where to start probing etc..thx
                You know what an LDO looks like?
                I'm going to Leeds Uni in about 5 months so keep a stash of TVs you can't fix for me .
                • sienoki
                  sienoki
                  • Jan 2012
                  • 314
                  PM me when you going to leeds uni & i will see what ive got to rid of as they are taking over my place & r lass is going nuts
                  • sienoki
                    sienoki
                    • Jan 2012
                    • 314
                    R these the LDO,s..thx
                      1,2 and 5 yep. Check all pins and note part # down.
                      • sienoki
                        sienoki
                        • Jan 2012
                        • 314
                        IC951=033ENA1=SHARP..thats topside
                        1. 5.02vdc
                        2. 4.88vdc
                        3. .045vdc
                        4. .041vdc
                        IC950 same part no & brand..bottomside
                        1. 4.81vdc
                        2. 4.88vdc
                        3. .027vdc
                        4. .018vdc
                        IC602=033DNA1=SHARP..bottomside
                        1. 18.07vdc
                        2. 10.14vdc
                        3. .029vdc
                        4. -.002vdc
                        all measured with power on black probe to chassis screw & red probes to each legs..thx
                        • sienoki
                          sienoki
                          • Jan 2012
                          • 314
                          1. 5.02vdc
                          2. 4.88vdc
                          3. .045vdc
                          4. .041vdc
                          1. 4.81vdc
                          2. 4.88vdc
                          3. .027vdc
                          4. .018vdc
                          1. 18.07vdc
                          2. 10.14vdc
                          3. .029vdc
                          4. -.002vdc
                          Ive taken 1/4 pics of both sides
                            Can you check the tab pin?
                            • sienoki
                              sienoki
                              • Jan 2012
                              • 314
                              The wire pin outs?
                                The wire pin outs?
                                You've got 4 pins on the bottom plus a fat tab on the top. The fat tab is probably the LDO output voltage. It is also used to heatsink the regulator.
                                • sienoki
                                  sienoki
                                  • Jan 2012
                                  • 314
                                  the tab pins readings..
                                  IC951=from OL to 3.27vdc
                                  IC950=same reading as IC951
                                  IC602=from OL to 3.28vdc
                                    What do you mean by OL, what range did you have meter on?
                                    • sienoki
                                      sienoki
                                      • Jan 2012
                                      • 314
                                      Got fluke77 on VDC quick O.L on display then the reading..thx
                                        That is normal for an autoranging meter. Assuming those regulators contain "33" in their part #, they are fine.
                                        Are there any other regulators? Like these:
                                        http://www.ictradenet.com/models_pic...PAK,TO-252.jpg
                                        http://upload.wikimedia.org/wikipedi...4/4f/D2PAK.JPG
                                        http://www.national.com/images/pkg/mp04a.jpg
                                        http://media.digikey.com/photos/Rohm...B1132T100R.JPG
                                        Anything you see that looks like those could be a regulator, so note down the part # and test the pins.
                                        • jord4231
                                          Toshiba 37AV500A Regza TV good power supply no sound no picture
                                          by jord4231
                                          Hi Everyone,
                                          I'm working on a Toshiba 37AV500A Regza TV.
                                          The issue:
                                          TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                                          The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                                          I checked the PSU voltages and everything looked good.
                                          No bulging caps or signs of heat.
                                          24v aud = 24.41v
                                          12v = 11.98v
                                          5v = 5.062
                                          p_o/f = Goes high...
                                          03-29-2022, 09:21 PM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 05:59 AM
