surface laptop model 1769
  • m3mo3y
    • 31
    • Sweden
    please can you clean my bios ?? i cant add new Post idont know why
    its a surface laptop model 1769
    thnaks a lot
  • peste
    • Dec 2016
    • 13451
    • ROMANIA
    Re: surface laptop model 1769
    try...
    • m3mo3y
      • 31
      • Sweden
      Originally posted by peste
      try...
      thank you so much for your reply, but unfortunately it still has the uefi password on it
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Because you did not ask for a password removal. You asked for clean which means ME cleaning, which peste did.
        Try this instead.
        • m3mo3y
          • 31
          • Sweden
          Try this instead.
          thank you so much man i love you
          i just want to know you have changed the 611A7A Offset value only !!
          is that how to unlock all the surfaces ?? or it just for this model ??
          thak you man again
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            Just one value, yes. Doesnt work on all surfaces.
            • m3mo3y
              • 31
              • Sweden
              ok and what to edit on the others?? i want to know so i dont ask every time i need , if you can tell me i will be so thankful
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                On some models you can just read and decrypt the password. Like on surface 3 pro. Then there is no need to remove the screen.
                But it is a bit trickier.
                • iTec
                  • Oct 2017
                  • 29
                  Hello, I have two units,
                  1- Surface 1769 changing that value didn't work, i keep getting the logo disappears after 3 seconds.
                  2- Surface 1867 changing that value result same as First unit.
                  On the 1st one I've changed the a whole block to FF following what one of the guys did here. The unit worked, but no touch, keyboard, trackpad working. UDID and other info are missing on the machine.
                  Any help or input is greatly appreciated.
                    • 21692
                    Start a new thread for the Surface 1867 .Off topic in this thread.
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      try...
                      goodluck
                      And for 1867 start new thread
                      • iTec
                        • Oct 2017
                        • 29
                        Hello, thanks for the help. I'll start a new thread for the other model...
                        With this file the unit starts Logo on and off few times then off.
                        Thanks.
                        • alex83
                          • Jan 2021
                          • 3
                          Try this instead.
                          is this a good bin for all Surfaces Model 1786 ?
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            I highly recommend always read your own bios content and modify that to avoid any potential problem like slow start, black screen, lost serial numbers etc.
                            Dont be afraid to upload your file, nobody bites and nobody asks anything in return to help
                            • bushmann
                              • Feb 2014
                              • 147
                              • Slovakia
                              Dear all.
                              Please can you help me with unlock password .
                              thanks so much.
                              • peste
                                • Dec 2016
                                • 13451
                                • ROMANIA
                                Originally posted by bushmann
                                Dear all.
                                thanks so much.
                                try this..
                                • vadik1533
                                  • Mar 2021
                                  • 2
                                  • uk
                                  ples remove uefi password and clean bios file
                                    • 21692
                                    Use a hex editor and you can do it yourself ,all the clues are here and in the other Surface threads.
                                    • bushmann
                                      • Feb 2014
                                      • 147
                                      • Slovakia
                                      try this..
                                      so until today i tried this file on the device.
                                      The password is cleared, the system starts normally, the touch on the LCD works, but when it is installed by the GPU drivers, the display is black.
                                      The system continues to work because I can connect via a remote connection and when.
                                      I uninstall the GPU drivers it works, but the system downloads and installs this drivers again and the black LCD.
                                      If I use the BIOS from another device so the password is cleared, the system boots for a long time, the touch on the LCD does not work, but it also works with the GPU drivers.
                                      • peste
                                        • Dec 2016
                                        • 13451
                                        • ROMANIA
                                        try..
                                        • Loki_Fido
                                          BIOS for Microsoft Surface Laptop 7 - Model 2036
                                          by Loki_Fido
                                          Hi ya folks,
                                          Attached is the BIOS from a Microsoft Surface Laptop 7 - Model 2036
                                          As of right now i am unable to confirm whether this BIOS dump works or not.
                                          But i will update soon. Hopefully in a day or two.
                                          Given that no one else uploaded any BIOS backup for this laptop, I thought i might as well start a new thread and upload what i have.
                                          Microsoft Surface Laptop 7th edition
                                          Model 2036
                                          SN 0F3CPFB24153HH
                                          Remember, If you tried to read this chip with CH341A, this device will not identify this chip for you.
                                          Both ASProgrammer...
                                          09-11-2025, 04:00 AM
                                        • arber1232
                                          Bios for Surface Laptop Studio 2 Model 1964
                                          by arber1232
                                          Hi everyone i need help
                                          Have a Microsoft surface laptop studio 2 1964 that in unable to pass the surface logo.
                                          S/N: ofo1fze221900c
                                          Model: Surface Laptop Studio 2...
                                          08-15-2025, 06:07 AM
                                        • Benass
                                          Surface Laptop 3 Not Detecting SSD - Need Help!
                                          by Benass
                                          Hey everyone,
                                          I'm having an issue with my Surface Laptop 3, and I could really use some help. I've tried everything I can think of, but my laptop just won't detect any new SSDs I install. Here's a rundown of the situation:
                                          Problem:
                                          • My Surface Laptop 3 isn't detecting any new SSDs, including a Sabrent Rocket 2230 256GB NVMe SSD and a Dogfish 256GB M.2 2230 NVMe PCIe Gen 3.0 x4 SSD.
                                          • Both SSDs work fine in other laptops, so I know they are functional.
                                          • The laptop does detect a Forsee 64GB SSD from my Steam Deck, and I can successfully install Windows on it.
                                          What I've Tried:
                                          1. Compatibility
                                          07-22-2024, 11:26 PM
                                        • Loki_Fido
                                          Surface Laptop 7 Model 2036 Boardview
                                          by Loki_Fido
                                          Hi ya folks,
                                          Anyone happened have the boardview for Surface Laptop 7?
                                          Not Surface Pro 7. That is a tablet. This is a laptop.
                                          Laptop 7 got released in 2024. Still kind of new,
                                          Check your coat pockets folks, im sure one of us has a boardview to spare.
                                          Thanks in advance
                                          Happy repairs
                                          09-15-2025, 08:17 PM
                                        • User2025
                                          Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
                                          by User2025
                                          I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
                                          It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
                                          I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
                                          04-29-2025, 04:13 PM
