Samsung 930b LCD cold start problem (inverter?)
  • retiredcaps
    • Apr 2010
    • 9271
    #61
    Re: Samsung 930b LCD cold start problem (inverter?)
    Originally posted by demens
    Noone has mentioned replacing that 2nd one.
    Post #47 and #50 both suggest replacing ALL.
    That purple can is 25V which suggests that it might help provide DC voltage to one or both of the inverter transformer (can't be sure without tracing the circuit or seeing a schematic).
    --- begin sig file ---
    --- end sig file ---
    • demens
      • Jul 2010
      • 9
      #62
      Well, i replaced the one closest to the pack. Tested it again, powering up the board without the rest of the monitor connected to it this time. Same hissing sound, now only 2 minutes.
      Replaced that last lonely one, didn't bother testing anymore, just re-assembled the monitor. Turn it on, no hissing, monitor works.
      Conclusion, listen to the advice here, replace EVERY SINGLE cap on the board and not just the one that looks bad.
      • retiredcaps
        • Apr 2010
        • 9271
        #63
        When PlainBill gets burned (from post #50 again) ...
        I tried to save money on a Gateway monitor. I didn't replace a couple of caps because 'they looked good'. It wasn't until I found this site that I learned that the $.28 cap I didn't replace was the reason the monitor still wasn't working.
        everyone surely will.
        • EGuevarae
          • Nov 2008
          • 1336
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • Windows 10 Pro x64
          • GeForce GT1050
          • BeastGTS
            • Sep 2010
            • 1
            #65
            I have a Samsung 930B monitor which started having the same symptoms as the original first post of this thread. The monitor started taking a long time to display any picture and the green power led started blinking rapidly, much faster than when the led was normally blinking in power saving mode. Eventually, it will not display any image at all, the power led just blinks rapidly, none of the buttons on the monitor respond, and no OSD is displayed. I have taken apart the circuit board and attached photos. Can anyone verify if it is the same bad capacitor problem? If so, which replacements should I obtain? Is digikey the recommended source for replacements?
            http://img26.*************/g/img4136e.jpg/
            • retiredcaps
              • Apr 2010
              • 9271
              #66
              1) Do you see the display if you shine a flashlight at it?
              2) Well, the caps look visually okay, but they could still be bad. Let's assume, for now, they are good and start with measuring voltages.
              3) If you have a multimeter, take voltages readings on the connector between power board and the logic board. You should get 5V DC on least one of the pins and possibly 12V or 19V DC as well.
              4) If you don't see the voltages above, then carefully measure the DC voltage across the large main capacitor. Careful, it is mains * 1.4 voltage.
              5) Also, you may have to desolder that green board that is upside down to get a picture. One person had a problem with a Samsung monitor about 5 weeks ago and it was a component on that board that was the problem.
              6) There is also a red fuse right next to the green board. Check to make sure the fuse reads less than 1.0 ohms.
              • RussTime
                • Nov 2010
                • 1
                #67
                I have this same monitor and had atleast 3 of the 820uf 25v CapXon the visually looked bad so I replaced with 1000uf 25v velleman caps, there was also a 1000uf 10v that looked bad so I replaced it also with the same 1000uf 25v velleman and still can see the check signal cable moving around on the screen when I shine a flashlight at it but even after letting it set plugged in for more than 20 min the screen never gets any brighter any suggestions?
                • tts2271
                  • Dec 2010
                  • 2
                  #68
                  Tech details on green fuse?
                  In case somebody cares, i just wanted to point out the procedure described earlier in the first posts also works with a faulty Samsung 930BF. Apparantly the PCB-Layout isnt much different and the problems are the same.
                  But has somebody managed to identify exactly the little green fuse? or at least has more technical specs about it? I just shortend it with a wire instead and it works, hope that wont affect the other circuits in a bad way...
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    #69
                    I think it's a 3A fuse. See post #26 and the post after on page 2 of this thread.
                    It won't affect the circuit in a bad way if everything continues to work properly. However, if one of the transistors in the inverter shorts, the whole power supply could get damaged. So with that said, better replace that wire with a proper fuse.
                    You need to use low ESR caps. The velleman caps you used most likely aren't.
                    Stick to the good brands like Rubycon, United Chemicon, Panasonic, Nichicon, and Sanyo. As for what series to use from these brands:
                    From Rubycon, you can use YXG, ZL, and even MBZ
                    United Chemicon - KY, KZE, LXY, and LXZ
                    Panasonic - FC, FR, FK, and FM
                    Nichicon - PM, PW, HE, and HD
                    Sanyo - WX
                    Also check fuse F301.
                    • tts2271
                      • Dec 2010
                      • 2
                      #70
                      definately check fuse F301!
                      Yes, especially check the fuse F301!
                      It was the same with my 930BF, changing the 820uF capacitors only brought back the picture with no backlight. After wiring the fuse the backlight came on and the whole display came back to life. Great thing!
                      • Logicsays
                        • Feb 2011
                        • 9
                        #71
                        I have the same monitor as mentioned in this thread. My symptoms are the green light comes on.. never blinks..just remains solid green. however if you push one of the other buttons.. menu etc.. you can see a faint flicker of light thru out the panel.. hard to see unless its dark... I guess I should start with the fuse?
                        • Logicsays
                          • Feb 2011
                          • 9
                          #72
                          also having a hard time locating the fuse. I viewed images of board posted and mine seems to be a bit different.. would this fuse be next to my caps? I noticed the tops of 3 caps are humped up compared to the rest of the caps.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Forget the fuse. Replace the caps!!!!
                            PlainBill
                            • Logicsays
                              • Feb 2011
                              • 9
                              #74
                              PlainBill
                              Thanks.. I ordered them yesterday. I'll let ya know how it turns out.
                              • Logicsays
                                • Feb 2011
                                • 9
                                #75
                                I replaced the three bulged caps.. no change. Solid green light nothing else.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #76
                                  1) Post clear focused pictures of your boards using the manage attachments function. Please do not post inline.
                                  2) What brand and series did you use for replacements?
                                  3) If the power LED is on, hookup a working computer displaying your favourite wallpaper. If you shine a flashlight on the screen, do you see the wallpaper?
                                  • Logicsays
                                    • Feb 2011
                                    • 9
                                    #77
                                    Re: Tech details on green fuse?
                                    Where is this fuse? My board looks identical to the images in post #60 Is it right next to the 3 caps in the white rubber goo?
                                    • Logicsays
                                      • Feb 2011
                                      • 9
                                      #78
                                      I replaced the caps with the mentioned digikeys replacements. I'll try to the flash light trick again before the caps being replaced I had nothing. I'll update
                                      • Logicsays
                                        • Feb 2011
                                        • 9
                                        #79
                                        The image is viewable with a flash light.. so something is working..
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #80
                                          Can we get clear and focused picture of YOUR boards? Referencing other people's pictures doesn't help us diagnose YOUR problem. Your board could have unique characteristics not shown in someone else's photo like a charred resistor or suspicious looking transistor.
                                          It is not uncommon for manufacturers to make changes on their boards. Also try to get the resolution as close to 2000x2000 as possible.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
