Sharp LCD LC-70LE660U
  • Vxavier
    • Jul 2017
    • 5
    Powers up back lights flash, I replaced the Tcon Board
    First power up worked great turned it off then back on no picture again.
    Unplug and reset ribbon cables powers up and works fine, Power down and
    back on nothing.
    Any idea where to start on this?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sharp LCD LC-70LE660U
    Need good clear straight on pictures of back of tv with cover off and each board.
    • Vxavier
      • Jul 2017
      • 5
      Here they are, Thank you for the assist!
      • dskall
        • Oct 2016
        • 2905
        • usa
        No picture as in no backlights. No image on screen
        • Vxavier
          • Jul 2017
          • 5
          The back lights flash then go off with no image on the screen.
          But if I disconnect and reconnect the Tcon board the back lights come on and I get picture
          As soon as I power it down and back on the back lights flash and no image
          • maxvalutech
            • Dec 2014
            • 804
            • australia
            Not clear on what cables you are referring to on t con are they screen or main board ?
            • Vxavier
              • Jul 2017
              • 5
              The 2 flat ribbon cables that goto what I'm guessing is the led drivers
              • maxvalutech
                • Dec 2014
                • 804
                • australia
                As far as I know those ribbons just build the picture. If so your actions must be acting as a switch to affect something else. Have you tried disconnecting main board lead to t con to see what that does to backlights. I understand LED turn on voltage has to reach a certain figure then drop back a bit - guys is this correct?. These circuits today can affect one another. Check voltage going to t con usually about 12v. What happens to that voltage when ribbons disconnected I.e. load reduced. Hopefully the people with real knowledge will comment.
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  on the connector that goes to your main board, can you take some measurements.
                  list it as
                  pin no, pin desc, v in stby, v when powered on, v when it faults
                  also v on the t-con fuse when running and when in fault mode as max has requested.
                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  • thoma
                    • Sep 2012
                    • 268
                    https://www.youtube.com/watch?v=MVGt7pV1-_E
                    http://www.avsforum.com/forum/166-lc...-thread-2.html
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      by sam_sam_sam
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                      This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      09-12-2024, 02:30 PM
                      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                      HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-06-2024, 08:10 PM
                      HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
