Good day folks. It's been a while since I've repaired a TV, so now I've got this small one I need a bit of help with. As the title says, the problem is that after it's been on for say 10-15 minutes, the picture begins to very slowly fade to white until it ends up looking really washed out and gray. I took the cover off to get to the t-con board, which is a t230xw01 and immediately noticed the very poor thermal design: at first I thought the metal piece that covers the t-con would also act as a heatsink, like in many other TVs, but no - it's just a piece of metal that stays over the circuit board and doesn't actually contact any of the parts to dissipate the heat, making it pretty much pointless. My main suspect is the AS04-F IC on the right hand side of the board, since it very much appears to be a gamma issue which is very common and often caused by failing ICs in the AS family. What do you guys think ? Cheers.
Samsung LE23R32B picture fading to white very slowly
Re: Samsung LE23R32B picture fading to white very slowly
Have you tried blowing air over the chip on the tcon and see if the picture stays. Use a fan or hair dryer set to blow and no heat.Willing to help but I'm no expert. -
No, I have not tried that exact method, although it did cross my mind and did something similar: I took a piece of scrap metal and a relatively thick thermal pad and sandwiched this whole contraption between the chip and the metal cover that goes over the T-con in hope it would dissipate just enough heat to solve the issue...I don't know if it did any good though, because the problem seemed to occur after the same amount of time.Wattevah...Comment
It may not be that chip but you could be right that it is a problem on the tcon so perhaps you could narrow down the problem using the fan/air flow.
It may be losing one of the voltages Vh, Vl, Vref etc.Last edited by dick_barton; 04-08-2017, 04:35 AM.Willing to help but I'm no expert.Comment
you could also try disconnecting one of the ribbon cables that goes to the lcd panel and see if the screen still fades out. if it still happens, reinstall the side you disconnected and try the opposite side and check again.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Good call...I guess the idea is to find whether something messes up on the buffer boards.Wattevah...Comment
If gamma problem post your vgm voltages 1-10. Do you have the gammacheck spreadsheet?
I would say you are losing one or more of your voltages on your t-con. This board is well marked for voltages so should be easy to check while picture good and after picture goes bad.Last edited by dskall; 04-08-2017, 11:58 AM.I assume no responsibility for any stupid suggestions I might post.Comment
I know the sheet you're talking about, it's in that thread about general repair tips I believe, but no, I don't have it right now. Should I measure the voltages with respect to chassis GND or to that REF test point on the far right (can't see it too well) ? I believe I should take a reading after a cold start when the picture displays properly and then after it messes up as well.Wattevah...Comment
Chassis ground. Here's spreadsheetAttached FilesI assume no responsibility for any stupid suggestions I might post.Comment
I tried that today and with the right buffer disconnected the picture is ok - albeit washed out immediately after turning on the set, it IS there. When I connect just the right buffer however, there is no picture at all - it's just a mess like you see in the picture, so perhaps the right buffer is indeed defective. Trying to keep the board cool didn't make much difference either, because the problem still appeared even with a small PC fan over the board. The large chip is only reasonably hot - I can hold my finger on it and it definitely doesn't feel like enough heat to cause any issues. The gamma IC is hotter though. I'll try taking some measurements as well.Wattevah...Comment
This is what my numbers look like immediately after a cold start. After the TV's been running for a while and it starts going gray, Voltages 10 to 7 increase by a bit - the higher the number of the test point, the higher the increase is, for instance V10 goes from 1.42 to 2.34, V9 goes from 1.73 to 2.52...the metal housing that contains the lamps also seems to get very hot and since the T-con is attached to it, it's like it's suffering from "thermal runaway" so what I did now was lift the board off the chassis entirely and prop it with some plastic trays from my parts bin to see how this goes....I don't think it will get very far though.Wattevah...Comment
Vg voltages progress from low to high/ high to low. Either way they should increase or decrease in an even manor. Though I think you have more than gamma problemsI assume no responsibility for any stupid suggestions I might post.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by DodgethisHello all,
This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...5 Photos -
by SrarosHello,
I picked up this TV with a problem showing white image.
When I unplug the right ribbon from the T-con to the panel board the right side is white with a dark shade at the edge and the left side shows perfect image.
When I unplug the left ribbon from the T-con to the panel board the left side is dark and the right side shows image but white. After a while the left side turns grey with vertical and horizontal lines. I found online that by swapping the AS15G it fixes images problems but not in my case.... - Loading...
- No more items.
