Vizio SV422XVT - Standby light, no image, no sound.
  • What?
    • Aug 2010
    • 82
    My problem started about 1 1/2 months ago, the tv failed to come on, had the orange standby light but when the power button on the remote was pressed the Vizio standby orange changed to white and blinked orange/white 24 times and then changed to steady orange. I checked fuses, looked for the obvious.... bad caps, burn marks, exploded components, bad solder joints and found nothing on the power board. Checked for voltage at connector CN201 which goes to the main board and found 5vdc only. No PS-ON, no 12V, no 18V, No BKLT-ON. I concluded the problem might be on the Main Board since 5V was reaching the Main. I tested all the fuses and found they were good, check all the caps for ESR and all were good, checked 4 voltage regulators and found U7 to be questionable,
    U7
    L362
    G1117
    Pin 1 (adj) = 1.259
    Pin 2 (out) = 2.506
    Pin 3 (in) = 5.128
    I changed the regulator with a used one from a scrap PC board I had laying around. The replacement regulator is identified only as LD1117 and after installation I got the following readings,
    U7
    LD1117
    Pin 1 (adj) = 2.24
    Pin 2 (out) = 4.17
    Pin 3 (in) = 5.09
    The tv lit up and I got the V logo and the menu on the screen. Woo Hoo! I hooked up a coaxial antennae cable and got a beautiful HD picture and sound. Did the happy dance! I leaped to the conclusion the problem was solved especially since Vizio has a reputation for bad LDO Voltage Regulators, buttoned it up and put it back on the stand.
    It has been 5 weeks working perfect, and then I tried to turn it on and got the original problem back. No image, no sound and blinking orange/white standby on the front of the tv. Heart break !
    Drop back 10 yards and punt, I thought maybe the "used" LDO failed but it is getting almost exactly the same readings as immediately after install. So...now what? I retested 4 Voltage Regulators, 4 fuses, all the diodes and continuity between the power board connector and the main board connector, tested all the resistors associated with the regulators,
    U5 U7 U71 U89
    L362 LD1117 L362 L362
    G1117 G1117 G1117
    Pin 1 = 2.095 Pin 1 = 2.258 Pin 1 = 0.001 Pin 1 = 0.001
    Pin 2 = 3.337 Pin 2 = 4.198 Pin 2 = 0.001 Pin 2 = 0.001
    Pin 3 = 5.121 Pin 3 = 5.127 Pin 3 = 0.109 Pin 3 = 0.01
    Fuses F4, F6, F10 and F13 all read 0.2 ohms.
    I did not remove the diodes as they are all SMD but none of them read shorted.
    I did not remove the resistors either for the same reason and they are really really tiny but none were open or shorted even though the readings were widely different between regulators.
    Sorry for the long winded explanation but it seemed necessary.
    Thanks so much for any assistance you may be willing to offer.
    Help?
    Last edited by What?; 07-27-2016, 01:25 PM. Reason: correct LDO ID number LD117 to LD1117
    Re: Vizio SV422XVT - Standby light, no image, no sound.
    U7
    L362
    G1117
    Pin 1 (adj) = 1.259
    Pin 2 (out) = 2.506
    Pin 3 (in) = 5.128
    U7
    LD1117
    Pin 1 (adj) = 2.24
    Pin 2 (out) = 4.17
    Pin 3 (in) = 5.09
    The reading you have BEFORE changing the U7 is correct, the Vdiff between pin 1 and pin 2 should be 1.25V which is what you have, 2.506 -1.259 = 1.247V which is the internal Vref of the regulator. If the regulator is good, the Vout will be = to 1.25Vref + Vadj, so 1.25Vref +1.259Vadj = 2.509 Vout.
    The replacement you installed has Vadj of 2.24V so the Vout should then be 1.25Vref + 2.24 Vadj = 3.49Vout. I can tell that it is not right because the difference between pin 1 and pin 2 should always be 1.25V. 4.17V is an odd Voltage for running the circuit, I doubt that the circuit designer comes up with that Voltage in mind.
    So the board has been running with higher output Voltage. Are you sure the resistor network that are connected between the PIN 1 and GND, and pin 1 and PIN 2 are still in place? I doubt that the original U7 was bad.
    U71, 89 do not have the input Voltage not until the main power supply is turned ON.
    https://www.badcaps.net/forum/showth...999#post300999
    • What?
      • Aug 2010
      • 82
      budm, thanks for your quick response,
      For some reason I had in my mind that the output should be 3.3v rather than 2.5v.
      I will remove the LD1117 and check the resistors and get back to you.
      Can you recommend a replacement LDO regulator? I don't think the original is available and I destroyed the original removing it from the board.
        1117 series Fixed or Adjustable is just a generic LDO which you can get them from DIGIKEY or MOUSER.
        • What?
          • Aug 2010
          • 82
          OK, it appears the resistor network is intact as well as the 2 capacitors....
          using a Fluke 115 meter set on ohms and an ESR meter I got the following reading,
          Pin 2 to R48 =.01 ohms
          Pin 1 to R48 = .01 ohms
          Pin 1 to R50 = .01 ohms
          R50 to GND = .01 ohms
          R50 to R48 = .01 ohms
          R48 = 94.8 ohms
          R50 = 110 ohms
          C38 ESR = .19 ohms and is connected pin 3 to GND
          C39 ESR = .09 ohms and is connected pin 2 to GND
          Pin 1 to GND = 110 ohms
          Pin 2 to GND = 204.7 ohms
          If the original VR was good and the tv did not work why did the tv start working when I put a bad VR in?
          I added a close up photo of U7 for reference
            So what was the Voltage reading of U7 (LD1117) when the TV failed the second time? 4.17V at the output?
            May be something got disturbed in that area and it starts working, I just hope that nothing got damaged running at 4.17V instead of 2.5V.
              Based on the value of R48 (FBr, 94 Ohms) and R50 (ADJr, 110 Ohms) measured in the circuit, the Vout should be around 2.7V.
              • What?
                • Aug 2010
                • 82
                Yes, Pin 2 (out) had voltage reading of 4.198
                I am hoping nothing got damaged too, the board is no longer available so it would be very difficult to get a replacement. I am thinking something got damaged, what else would cause it to quit.
                I had 3 identical salvaged boards with the LD1117 VR and I think the markings got messed up when I removed the one I used. I just dug out one of the other boards to verify the number and the ID is actually LD1117 25A. So that means it is a fixed 2.5V regulator, so if I change/remove the resistors to comply with installation of a fixed regulator it would put out the 2.5 volts instead of 4.17, right?
                  Yes you should get 2.5V for that 1117-25 fixed regulator.
                  • What?
                    • Aug 2010
                    • 82
                    Alright then, I will give a try!
                    • What?
                      • Aug 2010
                      • 82
                      budm,
                      How did you calculate the LD1117 Vout should be 2.7v?
                      • What?
                        • Aug 2010
                        • 82
                        Alrighty then, that worked, now I have Vo=2.5v @ U7. Actual measurements are:
                        U7
                        LD1117
                        25A
                        Pin 1 (gnd) = .004
                        Pin 2 (out) = 2.505
                        Pin 3 (in) = 5.115
                        I have included a photo of U7, I removed SMD R48 and R50, I soldered a jumper from Pin 1 to GND.
                        That solved the overvoltage at U7 Pin 2 but now I still have the original problem. The Vizio ON/STBY light blinks orange/white pauses on orange and blinks again. No screen image, no backlight, no sound.
                          The spec sheet of the 1117 has the formula for calculating the Vo.
                          I also made the spread sheet for it too, see post #6
                          To get the accurate result you will need to check the resistors values off the board.
                          So can you check the actual value of those two resistors?
                            BTW, so what dcv do have for the PS-ON, BL-ON pins on the power supply?
                            • What?
                              • Aug 2010
                              • 82
                              Still have the original readings at the power supply connector CN201 which goes to Main Board connector J1 and that is 5vdc only, no other readings.
                              The 2 smd resistors are very tiny and either due to my lack of experience or the equipment I have, both resistors were lost immediately after removal. I think they in a ball of solder in my carpet.
                                Try heating the main board with hair dryer, disconnect other boards (such as WIFI, IR board) that are connected to the main board except the power supply board and see what happen.
                                http://www.shopjimmy.com/catalogsear...Vizio+SV422XVT
                                • What?
                                  • Aug 2010
                                  • 82
                                  Holy Cow, I just found one of the resistors while I was cleaning up my work station. Actual reading is 110 ohms, that must be R50, but I have no way of knowing, sorry.
                                  • What?
                                    • Aug 2010
                                    • 82
                                    Ok, I will try the hair dryer. For what it's worth, I noticed the heat sink on one of the big processors is warm but the other one is cold.
                                      BTW, you may want to search badcaps site for the 'Vizio SV422XVT' to see other threads that may have the same problem as yours.
                                      • What?
                                        • Aug 2010
                                        • 82
                                        Thanks budm, I did a search before I posted and spent a few hours reading posts for the same model, that is what led me to the U7 voltage regulator.
                                        Heating the board mostly around area near the J1 connector did not make any changes. I don't have a can of air or freeze spray to try, I will have to run to Radio Shack to see if they carry it.
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • p-top
                                          Vizio, E60u-D3, no standby light, no ps_on
                                          by p-top
                                          Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                          main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                          PS voltages
                                          1 VSNS -2mV
                                          2-5 LED-OUT -2mV
                                          6-10 GND -2mV
                                          11 +16VS 16.29V
                                          12 AC-DET 3.929V
                                          13PS-ON -3mV
                                          14 +16VS 16.29V
                                          15 +16VS 16.29V...
                                          11-27-2023, 10:44 AM
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
                                        • shelby5041
                                          vizio d40f-j09 no pic no sound standby always clear
                                          by shelby5041
                                          hi
                                          anybody have experience with this model tv
                                          07-19-2025, 06:58 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
