O.K. first thank you all for the great posts. I have learned more about "Bad Caps" then I ever thought I wanted to know. Thank you in advanced as well for any comments you can make to help me.
I have read as many posts as I could before posting, so please go gentle on me if I miss something.
Here it is:
My 2 year old SyncMaster T240 started flickering early yesterday then eventually presented the classic "comes on for 2 seconds then goes off" symptoms. The only difference is that I can get the on-screen "Source" logo to display as I push the "Source" button on the side of the chassis. However, as soon as it hits the Input with any signal, DVI, HDMI, or VGA it does the "hey here I am then, hey there I go" thing.
I have taken the monitor apart and looked at the whole Inverter board. I cannot see any signs of obvious CapXon bulging, but I do see a slightly darkened area near two of the 820uF caps. that are near the long box coil (sorry, don't know the right name for it, but would love to know).
I am planning on proceeding with the Cap replacement procedures that have been listed in many posts here, however I have two problems.
1. I don't know if the dark browning I see on the board means something really bad, of is just a sign of bad soldering at the plant
2. The 820uF 25v 10mm X 25mm caps on the board are back ordered pretty much everywhere (I tried Digi, Mouse, several others both for Panasonic as well as any other low ESM brands, no luck). So I was hoping for some suggestions on where to get them, or some alternative replacements.
I have, or will attach picture of all the items I described above. Bellow please see a legend for the main up-side board picture showing the placement of all the interesting items that I could see.
A - 250V 15 AH fuse - seems to be ok but hard to tell because it is opaque not clear
B - 4 x 820uF 25v 10mm x 25mm 1050 Sam Young capacitors - no obvious signs of bulging
C - 2 x 1000uF 10v 10mm x 12.5mm 1050 Sam Young capacitors - again no obvious signs of defect
D - 330uF 10v 7mm x 10 mm Rubycon capacitor - same
E- 47uF 50v 1050 Sam Young capacitor - same
G - dark brown "burn" indication
Any pointers on the above would be appreciated. I was wondering if I could use higher 1000uF cap for the 820's because they are in stock. I also would like to know what that long wire warp is right next to the set of two 820's off by themselves is and whether or not it could be related to the problem stated above.
Thanks much
Anacryon
Here it is:
Thanks much
Anacryon
