I need bios.bin for Dell Latitude 5280
  • NOoFEARoNL
    • Jan 2015
    • 13
    • netherlands
    Hi all i need bios bin for Dell latitude 5280 motherboard CDM60 LA-E071P
    I want too use it for programmer CH341A .
    Big thanks in front ...
    • 21634
    Re: I need bios.bin for Dell Latitude 5280
    Make a bios backup and verify it, post it here with your service tag. You can try this bios at post #16 https://www.badcaps.net/forum/showth...highlight=5480
    The Latitude 5280/5288/5480/5488/5580 and Precision 3520 use the same 2 bios, vPro and non vPro .
    • NOoFEARoNL
      • Jan 2015
      • 13
      • netherlands
      thanks for your reaction i will try the 5480 bin if its not working i will come back to it
      • NOoFEARoNL
        • Jan 2015
        • 13
        • netherlands
        Thank you SMDFLEA i did what you said and went for the bin bios from the 5480 it worked perfectly
        you made my day thanks
        • lapfix
          • Mar 2020
          • 2756
          • my workshop
          Back to this one n i"m so confused !
          Latitude 5480
          The lap come with this issue : the customer say that during the bios update his lap is off ..try to power on ..light in power button but no fan no run...when i try to close the button don't reponde and alwys with light.
          So i try to flash the bios with one from site and clean it but nothing happen...try the SMDflea flash nothing too..
          My confusion is about the ME region version..not the same with the one from site and with the smdflea ...how to proceed !!
            • 21634
            Whats the service tag .
            • lapfix
              • Mar 2020
              • 2756
              • my workshop
              Thank you smdflea : BTHHLH2
                • 21634
                The service tag doesn`t match the one in the bios backup. If you go to the dell site and enter the tag you can look at the system config, listed under
                "look at the Product Details: View system configuration"
                631-ABEG : Intel Vpro Technology Enable
                379-BCTN : 6th Generation Intel Core i5-6440HQ (Quad Core 2.6GHz, 6MB cache)
                Dells can have different configurations, you can choose the CPU. This one has an i5-6440HQ ,and Vpro ,so the ME firmware will be Corporate H .Some of the other dumps on badcaps have Consumer firmware LP low power for the U based CPU`s . The bios you posted does have Corp H ,so cleaning the ME region might be enough. One of the problems when a bios has been messed with is you don`t know if someone has already tried to clean the ME themselves. Its best to find another 5480 bios with corp H FW and compare the 2 with FIT, often you`ll find that theres a difference,with boot guard missing,the public key hash or something else. When you open a bios dump with FIT it will retain the settings set by dell ,other "easy" 3rd party software won`t.
                • lapfix
                  • Mar 2020
                  • 2756
                  • my workshop
                  You confirm my doubts , thank you The GREAT SMDflea
                    • 21634
                    Try this one .
                    • lapfix
                      • Mar 2020
                      • 2756
                      • my workshop
                      Thank you SMDFlea , but same behaviour = light on power button when i press it , no fan no indication that there's a power on motherboard, when i try to turn off no respond and the light on power button still present .
                      I try with his battery not a charger or PSU.
                      notice thet the bios chip is not the same as mention on schematics.
                      i don't know if this message can disturb or not .
                        • 21634
                        The bios was merged with the latest dell update and ME firmware extracted from the dell bios update.It doesn`t matter that the ME firmware is newer,its not a problem,its the one that dell provides with the update.
                        What part number is the bios chip ?
                        • lapfix
                          • Mar 2020
                          • 2756
                          • my workshop
                          OK , in the schematic = W25Q128FVSIQ
                          In motherboard = 25B128CSIG
                            • 21634
                            The bios chip is ok,its suppoerted. I don`t know where your problem is. Try flashing the EC
                            • appu4009
                              • Mar 2018
                              • 1
                              • India
                              la-e071p Rev1.0 tpm is missing need bios plz.....Dell Latitude 5280
                                • 21634
                                Try these suggestions before flashing the bios
                                https://mrtechbot.wordpress.com/2019...tialize-error/
                                • appie1206
                                  • Oct 2016
                                  • 116
                                  • netherlands
                                  can u help me with unlock this one for me i tried everything!!
                                  Thanks in advance!!
                                  • Mrnixdorf
                                    • Sep 2016
                                    • 127
                                    • Morocco
                                    SERVICE TAG F6WC9H2-E7A8
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      https://www.badcaps.net/forum/showpo...42&postcount=4
                                      Become a Badcaps supporter
                                      Thanks to all supporters.​
                                      • Kamlesh Soni
                                        • Aug 2024
                                        • 12
                                        • INDIA
                                        Can anyone please clear bios me region of this model
                                        Dell Latitude 5280
                                        SN: 7X0QPL2
                                        It's turn on and Black screen
                                          DELL Latitude 5280 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5280 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5280 boardview and 5280 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5280...
                                          09-06-2024, 06:14 AM
                                          09-06-2024, 06:10 AM
                                          09-06-2024, 05:59 AM
                                        • diamon
                                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                          by diamon
                                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                          Pictures of these boards:
                                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                          Dell...
                                          02-28-2024, 12:51 PM
