looking for HP 450 G1 boardview link if it was posted on the forum please
  • medrek
    • Mar 2016
    • 10
    • ethiopia
    hi today i was trying to ripair hp probook 450 g1 its problem is when it is plag in the charger conecter the LED blink continously when i turnon it wont turnon their is no 3.3v or 5v but their is 19v so if any one solve this problem pls help or if u have the schmatic
    thanks
  • kimrocco
    • Jan 2014
    • 56
    • F2
    Re: [help] hp probook 450 G1
    HP PROBOOK_450 G1 wistron
    • tibd
      • Oct 2014
      • 189
      • Sweden
      Start by checking if middle pin connector is shorted to ground.
      If so change D4201
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        thanks
        If the bios is corrupted it could do this. I had a problem with an Acer that did this and after I took out the battery, disconnected the adapter, pressed the power button and held it for 30 sec. and took out the bios battery it was alright when I put it back together. I believe when the power saver mode turns on sometimes it can can cause the unit to go into some loop fault when there is none. Perhaps if the Bios is re-flashed it would correct this problem?
        • bachir2004
          • Feb 2015
          • 439
          • maroc
          Rampage mb 12241-1 48.4yw03.011 schematics
          Does anyone have schematics of HP Probook 450 g1?please.
            • 21853
            Re: Rampage mb 12241-1 48.4yw03.011 schematics
            https://www.badcaps.net/forum/attach...5&d=1505291915
            • bachir2004
              • Feb 2015
              • 439
              • maroc
              thanks
              • MtapeK
                • Sep 2020
                • 38
                • Zimbabwe
                  • 21853
                  Re: looking for HP 450 G1 boardview link if it was posted on the forum please
                  What is the motherboard part number ?
                  • MtapeK
                    • Sep 2020
                    • 38
                    • Zimbabwe
                    Rampage_MB 12241-1 48.4YW04.011
                    AND
                    Rampage_MB 12241-1 48.4YW05.011
                      • 21853
                      The boardview doesn`t seem to be available sadly, only the schematic.
                      • MtapeK
                        • Sep 2020
                        • 38
                        • Zimbabwe
                        thanks very much
                        • pcconnect
                          • May 2019
                          • 81
                          • uk
                          Hello, I have the same symptoms and in my case it was a blown capacitor C4916. (I hope as I didn't power the board up yet after removing it)
                          The question is is it a 22uF 25V one?
                          I have many donor boards and can't find this cap on any of them so far. Do I read it correctly?
                          Thank you
                          • AL._.EX
                            • Dec 2022
                            • 896
                            • Belarus
                            22mkF 25v
                            The laptop will work without this capacitor).
                            • pcconnect
                              • May 2019
                              • 81
                              • uk
                              Originally posted by AL._.EX
                              22mkF 25v
                              as you said, works!
                              thanks
                              • lilopy
                                • May 2017
                                • 1
                                • paraguay
                                Thank you
                                Could you please show me where that C4916 capacitor is on the motherboard? I've searched a lot and can't find it...​
                                • dokma
                                  • Aug 2017
                                  • 39
                                  • Croatia
                                  I've just repaired an HP 470 G1 which also died due to C4916 but also suffered an exploded first mosfet which welded the pads. I had to rip the pads off and bridge plus line from a nearby test point with my NAKED EYE.
                                  • GabrielT_03
                                    • Jul 2025
                                    • 6
                                    • colombia
                                    thanks
                                    Hello friend, cordial greetings. Were you able to find a solution to this error? I have the same problem where the charging connector's LED flashes and I haven't been able to solve it.
                                      HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-07-2024, 07:12 AM
                                      09-07-2024, 06:40 AM
                                      HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                      This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                      09-07-2024, 05:50 AM
                                      HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                      09-06-2024, 10:51 AM
