Picture issue blurred lines Toshiba 26AV502r
  • Gadjet
    • Aug 2012
    • 248
    Here is a picture of what I'm getting
    Re: Picture issue blurred lines Toshiba 26AV502r
    Does this occur on both analogue and HDMI/digital input? Does it affect the menu/OSD too?
    • Gadjet
      • Aug 2012
      • 248
      Yes even in the osd menu
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
        09-06-2024, 05:27 AM
      • noisykid
        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
        by noisykid
        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
        12-30-2024, 07:15 PM
      • netgearnetgear
        TOSHIBA 32C100U1 - Faulty display (double images and lines)
        by netgearnetgear
        Good day all,
        I have a Toshiba TV, model 32C100U1 that turns on, displays fine for 5 min, sometimes 10 min and even 25 min then it starts to show double image, wrong colours together with lines as seen in the attached. I have measured and documented the tcon voltages both when the Television works fine and when the problems described occurs. It is important to note that the voltages are the same on the tcon board. The LVDS cable, tge panel ribbon all test good. I resoldred all the main ic's connections pins, connectors and even reflowed gamma chip. I tried to block some of the...
        10-27-2025, 08:07 PM
        09-06-2024, 05:59 AM
